It is currently Tue Nov 17, 2026 3:30 pm
PostPosted: Mon Feb 28, 2005 12:18 pm
Hey all,
I'm here in the SF Bay Area and my girlfriend just surrendered her 66 Barracuda to me. She bought a Bug, Easier and cheaper for her to work on.
She had the 3 speed pulled and overhauled. What i need now is to get the linkage back together correctly. I want to remove as much of the "slop" as possible out of the column shifting. (until i get it converted to floor shift.)
I either need advice or a referral to a Mopar competent trans shop.
Steve
PostPosted: Mon Feb 28, 2005 9:57 pm
What transmission is it? I have the "five feet deep" factory Plymouth service manual, I could get you all the info you need.
PostPosted: Mon Feb 28, 2005 10:25 pm
There is not much to those.
Shim the linkage connection points so everything is tight and look for the adjuster at the base of the column. There are 3/8 hex head bolts in slanted slots. Loosen the bolts and rotate the adjustment sleeve to tighten up the column bushing.
 Post subject: Slanted Slots
PostPosted: Wed Sep 21, 2005 9:34 am
Ya know I did find those but it appears that it's already been done. (the bushing is rotated as far as it can go). Is this a rebuildable area of the column? if so does anyone make a "kit"?
I am ordering the grommets and bushings for the rod to trans brackets today.
I'm hoping ot be able to bring her up to the Slant Six meet Sunday.
Steve
