It is currently Thu May 21, 2026 5:19 am
PostPosted: Mon Feb 28, 2005 2:54 am
is it safe o lift engine from under crank snout?...need to raise engine higher than i can from under bellhousing,,,thanks
PostPosted: Mon Feb 28, 2005 7:30 am
No, you risk bending the crank. Find another way.
Mitch
PostPosted: Mon Feb 28, 2005 3:13 pm
Just how would you bend the crank?
The engine will only go so high, sooner or later you will hit the firewall or the floorboards.
PostPosted: Mon Feb 28, 2005 11:07 pm
Use a block of wood under the oil pan and jack it up. I don't think it will bend the crank lifting under the crank snout, but I think you can damage the #3 thrust main bearing.
PostPosted: Tue Mar 01, 2005 7:52 am
Yeah, what Eric said. Jacking on the snout not only can damage the pulleys but can also damage the bearings in the motor. A block of wood under the oil pan will do the trick. It works for installing transmissions too.
PostPosted: Tue Mar 01, 2005 8:04 am
I think this is one of those "you'll put an eye out!!!" kinda things... It's not recommended, but certain situations in the field create a need to do such a thing. I won't gaurantee you won't "bend your crank!" or, "damage the thrust bearing!" and I definitely wouldn't be surprised if you did %*@# up your pulleys, but going slowly and using something soft to spread the load, I doubt it will cause you problems. I have done it several times with no apparent ill affects in many, many miles. ...but don't try this at home! ;)
D/W
If it ain't broke, fix it!
PostPosted: Tue Mar 01, 2005 9:47 am
Block(s) of wood have given us that extra lift we needed on several occasions. Make sure the jack is stable on a good surface and the wood block(s) is centered well under the load point. DON'T get underneath anything you are lifting, unless you have it blocked or chained up securely.
Jerry
