It is currently Fri May 29, 2026 9:57 pm
Post new topic  Reply to topic  [ 30 posts ]  Go to page Previous 1 2
PostPosted: Wed Mar 02, 2005 8:49 am
I bought the Haynes Repair Manual for RWD Mopars 1971 - 1989, it has been very helpful; also browsing this site is great... there is a forum regarding tuning up, and read a good advice given to other Slanter about dialing it in (guess that is the right term). But there are a lot of loose ends. I will keep posting questions and results... hope not to be anoying.
My other car is... another DUSTER!!! .·.
PostPosted: Wed Mar 02, 2005 8:53 am
JUST ANNOY US! :D
PostPosted: Wed Mar 02, 2005 9:30 am
Thanks Rust... but don't tell I didn't warn you :D
Here is a pic of my baby in the works...
PostPosted: Wed Mar 02, 2005 10:07 am
What year is your nova?
My uncle had one just like it :roll: :wink:
PostPosted: Wed Mar 02, 2005 10:27 am
It is not a Nova (did you mean Chevy?)..., it is a Valiant Duster 74. This car is the Mexican version of the Dart Sport. The main difference between the Mexican Duster and the US Dart Sport are the tail lights, the Mexican model did not have the four square lenses until 76, year in which the front grill changed exactly as the US Duster. There were no Plymouths in Mexico in the 70's, only Dodge and Valiant. The Mexican Valiant versions were similar to the US Plymouths
Here is another pic on the side, sorry it was dirty then, now it is a beauty.
PostPosted: Wed Mar 02, 2005 10:30 am
I don't know what happened with the image... I will try to post it later.
PostPosted: Wed Mar 02, 2005 10:45 am
Dont worry, just kidding...
Looks like a nice project.
Hmmm, Really looks better than any of my cars :cry:
PostPosted: Wed Mar 02, 2005 10:53 am
Gosh!!! I did not catch your joke, boy do I feel stupid with all that info on Mopars I posted; it is like teaching the Pope how to pray!!!... :oops: It got me off guard...
I was really worried about my car... thought I might be in the wrong place, I am a rookie, but not that much :P
PostPosted: Wed Mar 02, 2005 11:14 am
Well I didnt know how the cars in mexico are different from the us. built ones, so it was nice to get some info on it...
So, how are things going, except reading and cleaning?
Have you got some ideas about what you are going to do with it?
And that is the first time I have been compared to the pope...
But I guess it will be the last too
PostPosted: Wed Mar 02, 2005 11:54 am
that is the first time I have been compared to the pope... But I guess it will be the last too
Hopefully :lol: :lol:
It's a very spanish languaged comparision tht's actually funny, since in about two months they gonna have to teach him how to pray and maybe some diapers would be involved.... (no offense intended neither to you, rust collector, or to the pope)
Hola Dustermunster
que hay guey, te sirvió de algo la info que escribí? si tienes ganas y tiemo visìta www.clubdodge.com.ar y fíjate por lso foros, un artículo que ecribí hace tiempo y que se llama RECURVANDO EL DISTRIBUIDOR.
Por supuesto serás más que bienvenido a usar el e-mail directamente, puedes conectarte conmigo a jic@jicaino.com.ar
Saludos/Cheers to everybody.
"Slant Six.org the primero spanglish forum" :lol:
Juan Ignacio Caino
PostPosted: Wed Mar 02, 2005 12:12 pm
Rust, I planned to start today with all the advices given by you and the other guys in this forum regarding timing and dialing it in... but in an earlier post I mention that my carburator started to spill a lot of gasoline. I already checked a lot and could not find the problem. I opened it to check it from the inside and nothing was wrong, I bought the gasket set and a carburator cleaning spray. The float is ok and everything seems to be in place, even a small "ball" that fits in; but still there is a gas flood in my engine bay. So I decided to replace the carb with a recon... it is not expensive, about $750.00 pesos ($68.00 dollars) including the core credit.
I will pick it up tonight to proceed with the timing adjustments that are my headache.
Juan: Of course it was of great help what you wrote, thanks a lot... I just need to install back the carb and will see if I can achieve the task. Gracias por tu invitación a clubdodge.com.ar inmediatamente leere tu artículo, seguro es muy interesante y me servirá mucho. Y gracias por usar el término "guey", lo siento muy mexicano. I will contact you for sure directly.
This guy is a genius and a very cool guy, he even plays the sax and restores vintage musical instruments... way to go Juan.
PostPosted: Wed Mar 02, 2005 2:21 pm
Great distributor article Juan, a little bit too advanced for my current Slanter status but will work on that... sounds great, more power and less fuel consumption. You should translate that into English and publish it here in the articles section. 8)
PostPosted: Wed Mar 02, 2005 5:03 pm
I've seen your posts here DusterMunster, seems you're having fun with your car. Keep it up, all the headaches are worthed when you see the final result and realize how much you have learned. Just an advise: be very careful when tampering with gasoline, I read your post in which you mention the deluge of fuel. I had once a '75 Scamp that caught fire with a similar problem. Gasoline is very flamable and I didnt know that it could ignite with the heat of the exhaust manifold.
I can see you've got good advices in here. Keep asking, and pay close attention to each suggestion and advice, I saw you are not experienced, but it seems Rust Collector, argentina-slantsixer, Slant6Ram and the others are helping a lot. Good luck
CL.
PostPosted: Thu Mar 03, 2005 8:17 am
Thanks Corey, you're right, these guys rule... 8)
PostPosted: Fri Mar 04, 2005 6:03 pm
Way to go Juan...Así es como se hacen las cosas.....¡Andele, ándele, arriba, arriba...yepa,yepa! :lol:
Maybe we should request the addition of an all spanish section for us S.O.B's
(that's South Of the Border)
Rafa
Hecho en México
Users browsing this forum: Google [Bot], slantzilla and 5 guests
