It is currently Fri May 08, 2026 6:19 pm
 Post subject: HEI Mounting?
PostPosted: Wed Mar 02, 2005 10:31 am
Car Model: 1962 Lancer 770
Ok I finally got all my parts assembled for the electronic ignition conversion. I was wondering where people have mounted the HEI control module. I just have a piece of aluminum that I was going to screw to the RS Fender someplace so its near the coil and distributor. Is that a poor location due to water penetration vs. perhaps the firewall? Anyone have a picture of where they mounted theirs?
Also any tricks for distributor R&R?
Thanks in advance!
 Post subject: Anywhere
PostPosted: Wed Mar 02, 2005 11:16 am
As long as the ECU has a good ground, you can mount it any place you like.
The ECU is reasonably weather resistant.
My Aspen has it mounted on the fender, my truck is now on the fender.
My truck has holes on the firewall for a the old factory location for an ECU (it's origionally a lean burn) I would have mounted the ECU in the factory location, but the wires wouldn't reach. :roll:
Pic a spot that looks pretty. :wink:
1980 Aspen 225 super six
PostPosted: Wed Mar 02, 2005 11:19 am
Ah shucks...whereever looks pretty! :D
I have tons of wire so I can mount it anywhere. I'll look tonight and post back the decision.
MJ
PostPosted: Wed Mar 02, 2005 11:23 am
I would not worry, as long as water dont stay in the same spot.
PostPosted: Wed Mar 02, 2005 12:18 pm
the best placing sot for a HEI is a GM firewall :lol:
now really, slantsixram advice is good.
Juan Ignacio Caino
PostPosted: Wed Mar 02, 2005 3:24 pm
mine is mounted on top of the inner fender. mine is flat and well protected up there. I need to go out and get a bunch of pics from under my hood again. I lost all of them a couple months ago.
GM HEI arent mounted on their firewall they are under the distributer cap
 Post subject: Did I say that?
PostPosted: Wed Mar 02, 2005 5:12 pm
I completely missed the fact that we were talking about a GM HEI :oops:
I swear it said ECU the first time I looked at it. :shock:
PostPosted: Wed Mar 02, 2005 5:34 pm
Ah I knew you knew what I meant ;-) I just ignored that ECU specific part ;-)
MJ
