It is currently Fri May 22, 2026 2:49 am
 Post subject: Engine Life Points
PostPosted: Fri Mar 04, 2005 6:05 am
Never pulled a slant before, but I do have lots of experience with V8's. Where do you attach the engine hoist when pulled engine and trans at the same time?
PostPosted: Fri Mar 04, 2005 8:19 am
there are two 3/8 sae bolt holes between valvecover and manifolds... i use a short chain between the two
 Post subject: Choices
PostPosted: Fri Mar 04, 2005 8:43 am
I use a heavy nylon strap (read 'old dog leash') :o
I tie one end to the #6 exhaust runner, and pull tight attaching the other end to the #2 exhaust runner. This balances the engine and transmission perfectly and allowed me to pull by myself, one hand tilting the motor the other working the hoist. Only works if you have the manifolds attached. I should have shot a pic, It was beautiful :cry:
If the head has 3 lifting holes (like later heads), use the middle and rear hole for the short chain and lift from the middle of that chain. Should balance about the same as my first suggestion.
1980 Aspen 225 super six
