It is currently Sun Nov 15, 2026 4:37 pm
Post new topic  Reply to topic  [ 39 posts ]  Go to page 1 2 3 Next
 Post subject: Tranny line filter
PostPosted: Wed Mar 09, 2005 8:26 am
I have a large tranny filter that mounts to the side of my 225 slant 6. It is a line filter of some sort. It is about the size of a pop can. I would like to replace it. Where can I find one. 1962 Lancer GT
PostPosted: Wed Mar 09, 2005 8:57 am
Go fish. That external filter was introduced as an accessory in late '61, made standard equipment in '62, continued for '63 and replaced by the now-familiar in-pan filter for '64. The last source was Fram (P1651PL) but it's been discontinued and no stock remains anywhere.
Unless you need the filter for the original appearance, it's much less hassle in the short and long run to simply remove the external filter and replace it with a section of appropriately-formed/appropriately-specced hard or soft line, then replace the in-pan screen with the '64-'65 2-hole in-pan filter.
PostPosted: Sat Mar 19, 2005 6:41 am
hi i might be able to get that part # for you i just called a friend at the local auto parts store and they do not have them in stock but they can still get them as a special order for about $30.00 if you need me to help you out just let me know i can order them for you
thanks
Dustin Butler
roadrunner7169@hotmail.com
PostPosted: Sat Mar 19, 2005 8:26 am
That'd be a neat trick since they're no longer made—maybe your guy has access to old stock off a warehouse shelf? I need some of these for another application; will you let us know what actually happens if he winds up ordering one?
(For actual Mopar use, the '64-'65 in-pan filter is still the best way to go)
PostPosted: Tue Mar 22, 2005 5:15 am
hi i just got my friend to order them filters the other day and he could only get one (from his local whorehouse)and when we got it yesterday i had to send it back cuz it was smashed other than that iv got no other source for them
sorry
DUSTIN
ROADRUNNER7169@HOTMAIL.COM
PostPosted: Tue Mar 22, 2005 6:11 am
Roadrunner, I would never have thought of looking there for a filter!
PostPosted: Tue Mar 22, 2005 7:53 am
Now, that's what I call full service. :oops:
Jerry
 Post subject: Spin On Filter
PostPosted: Tue Mar 22, 2005 2:29 pm
Hi i was checking my inventory and i found out we have a spin on type filter available if you can find a filter relocation kit for the car i may have a filter for you if you need the dimensions on it i can get them for you
thanks
DUSTIN
 Post subject: Re: Spin On Filter
PostPosted: Tue Mar 22, 2005 2:47 pm
These universal spin-on trans filter kits don't directly replace the '60-'63 inline trans filter.
Also, important, I've just learnt that you need to use a '64-up pan if you use the '64-'65 filter.
PostPosted: Tue Mar 22, 2005 3:34 pm
Has anyone tried crossing that number over to an industrial application?
What other applications did that filter fit? I would bet there was some other obscure use for that filter on a forklift, tractor, etc. that LPM or Luberfiner picked up. Ive come across all kinds of old style filters that are still being produced for relics.
PostPosted: Tue Mar 22, 2005 3:48 pm
It was an industrial filter that just happened to be used on Mopars. That's the problem; it's been disco'd at the source.
PostPosted: Tue Mar 22, 2005 4:25 pm
ok, now Im a lot more convinced someone, somewhere, is still making them. Not Fram, which is probably a good thing, but if you can come up with a specific application I bet you it'll be listed in the LPM or SMH catalog. I can still get bypass filters for the 4 cyl Chrysler flathead. I got a trans filter from them for a first generation Towmotor I helped restore for a showroom years ago, that thing was one of 200 built...
betcha I can find it... :) it might be in Belgium but it's better than nothing.
PostPosted: Tue Mar 22, 2005 4:38 pm
Only additional info I have on that filter is the following part numbers:
Jeep 3168060 (Chrysler J3168060)
GM 715102
GM 5579826
PostPosted: Tue Mar 22, 2005 4:57 pm
Do you know when roughly it was discontinued? I can try to cross the Fram number over. I might need to use an old catalog.
PostPosted: Tue Mar 22, 2005 5:02 pm
It was disco'd in the last few years; if you have a 5- or 6-year old catalogue it ought to be in there. I will be very pleasantly surprised if you find a cross for it; there were no crosses to other filter makers when I checked about 12 years ago.
