It is currently Fri Jun 19, 2026 6:46 pm
 Post subject: need some direction
PostPosted: Sun Mar 13, 2005 8:40 am
I'm just before pulling my /6 out. I want to rebuild and soup it a bit. Don't really know which way to go. I'm leaning towards the 4 barrel intake, dual exaust and what ever else needs to be done. Any help on what to do would be helpfull.
Thanks Kevin
PostPosted: Sun Mar 13, 2005 8:45 am
Put a bumpier cam in it, definitely mill the head a bit, and consider doing/having done some porting work. A "split" manifold or headers. It's just a slanted air pump, and you've got to get it to where it is less restricted and flows more air to take advantage of that 4 barrel.
D/W
If it ain't broke, fix it!
PostPosted: Sun Mar 13, 2005 11:45 am
Thanks Dennis, Do have any suggestions on any particular supplier? I've noticed that Clifford is one source for headers and intakes. Are they any count or do you suggest any others?
