It is currently Tue Jun 16, 2026 3:41 pm
 Post subject: Next round of questions
PostPosted: Mon Mar 14, 2005 12:11 am
Well, we made lots of progress this weekend. Got most everything back into the engine bay. Now, I need a little help with a few items...
Is this the correct location for this ground wire?
Where do the wires route on this side of the engine? Do they go along here with the heater hoses, or below them?
What does this brace on the dipstick bolt to?
What do these two large black connectors and the eyelet mount to?
I'll have more questions for you as we button this thing up.
Thanks for any input,
Jerry
PostPosted: Mon Mar 14, 2005 8:01 am
The dipstick brace bolts to the throttle spring and kickdown linkage bracket, which is secured to the underside of the two outboard intake-to-exhaust manifold bolts.
The wires in your last picture appear to be part of the factory A/C system. That flat 2-prong connector will likely find a home on an A/C clutch-cycling or binary-pressure switch.
The wires that come off the firewall and around the corner of the rocker cover are actually held to the firewall by screwed-on J-clips (or, on some cars, "finger" clips that look like the ones on the distributor side of the rocker cover).
I would comment on your first photo but I can't get a frame of reference. Where is this? What's the view?
PostPosted: Mon Mar 14, 2005 8:27 am
Hey Jerry,
I'm about 6,000 miles from any of my Slanted cars, so I won't be of much help on the routing and attaching of things.
The one thing I noticed that Dan didn't mention... On all of your ground wires, make sure you remove some paint where the wire meets the grounding surface so you get a good ground. Those little pesky problems can be a real frustration.
It sure must feel good to be putting it back together!
PostPosted: Mon Mar 14, 2005 1:36 pm
Dan, I think I have the A/C already taken care of with another wire. Our little makeshift tags you see on the wires refer to what I called (in my ignorance two years ago) "choke heater". Unfortunately, at the time we did not label where the eyelet goes. The first photo is taken from the driver's side looking over the top of the battery tray at the front clip. You can see the transmission cooler on the right.
Rob, good idea about the grounding wires. And yes, it is a VERY good feeling getting this car put back together. Aaron is beginning to get very excited.
Jerry
PostPosted: Mon Mar 14, 2005 4:36 pm
Jerry, the ground eyelet from that wire harness (last pic) goes to the bolt that holds down the cylindrical vacuum switch (has to do with the EGR, I think) to the cylinder head. The braided ground wire from the firewall usually goes there too.
As for the two wire connector, it goes to the little cylindrical vacuum switch that mounts in between the No. 5 intake/exhaust runners. This switch has two electrical connections side by side and has a vacuum port that connects to the vacuum amplifier.
Erik T.
1974 Dodge Dart Swinger - 225, A904, 8 1/4, B5 Blue w/ White Vinyl
1982 Chrysler Cordoba - 318 Lean Burn, A999, 7 1/4, VC4 Glacier Blue w/ Dark Blue Vinyl
PostPosted: Mon Mar 14, 2005 5:16 pm
I don't have a problem with that... the correct location isn't a big deal in terms of functionality as long as it's a good connection. I'm used to seeing a ground wire on either side of the rad support where the headlamp harness passes through. Looks good to me.
