It is currently Fri May 08, 2026 7:48 pm
 Post subject: Torque Converter
PostPosted: Mon Mar 28, 2005 9:39 am
what stall speed would you guys recommend for a daily driven dart with a comp cams 264? im sure ill hit the track sometime but my main focus with this car is a quick daily driver. any suggestions would be appreciated.
PostPosted: Mon Mar 28, 2005 1:19 pm
2500 RPM stall will feel almost like a stock converter until you hammer it, and shouldn't lose you gas mileage. Should be enough stall for that cam.
In my experience, converters up to about 2800 stall (9.5-10"), if built right, don't sacrifice much driveability or mileage over a stock converter.
Make sure you get stall quoted for a Slant and not a V8. If you order a 2500 stall for a V8 it will stall around 1800 on a Slant.
PostPosted: Mon Mar 28, 2005 1:46 pm
what does a stock converter stall at?
PostPosted: Mon Mar 28, 2005 2:16 pm
About 1800. :shock:
 Post subject: Why the difference?
PostPosted: Mon Mar 28, 2005 5:37 pm
Why do convertors exhibit different stall characteristics with V8's than sixes?
Cheers!
Al T
PostPosted: Mon Mar 28, 2005 5:47 pm
I don't know the technical specifcs of it Al but I recall reading it has to do with the motors torque, the less torque the lower the same converter will stall.
Call Andre at www.edgeracingconverters.com I bought my converter (not yet installed but came recommended from someone else on this board). He was very straight forward and good to deal with. Ask him what he recommends, and also check out their website.
