It is currently Sat Jan 03, 2026 12:08 am
 Post subject: rod bearings mis hap???
PostPosted: Sat Apr 02, 2005 4:55 pm
Does anyone know the part number since autozone and advance cant get me the right bearings for a standard 225 ???? Any help would be so appreciated!!! Thanks
PostPosted: Sat Apr 02, 2005 5:15 pm
What year engine are you working on? What, if anything, has been done to the crankshaft?
PostPosted: Sat Apr 02, 2005 5:42 pm
I would have to add, what undersize (if any) have the rod journals been ground to and are the journals damaged? Because if the rod journal is wiped, you are going to either have to regrind or replace the crank. Dont bother picking up any bearings until (or unless) you know this.
PostPosted: Sat Apr 02, 2005 8:32 pm
1960-1975 forged crank-
Michigan & Michigan 77: CB606-xx or 7375-xx
TRW: 2375-xx
Sealed Power: 2375CP-xx
1976-1986 Cast Crank-
Sealed Power: 3695RA-xx
xx= the undersize demension in thousands of an inch. Such as 10, 20, etc.
PostPosted: Sat Apr 02, 2005 8:33 pm
Good P/N info -- remember, the forged/cast crank changeover was in midyear '76.
PostPosted: Sat Apr 02, 2005 10:15 pm
I would assume he would want to get a forged crankshaft in the event of damage? Or is it a matter of a cast crankshaft fitting a later block?
PostPosted: Sun Apr 03, 2005 5:45 am
The forged crank cannot be installed in the cast crank block. The block, crank, and rods are unique to each other.
PostPosted: Sun Apr 03, 2005 4:23 pm
I would assume he
COUGH *ahem*
Users browsing this forum: Bing [Bot] and 13 guests
