It is currently Mon May 04, 2026 4:02 pm
 Post subject: Power brake booster?
PostPosted: Fri Apr 01, 2005 5:18 pm
Is there a power brake booster/master cylinder that I can use to
replace my stock master cylinder? It's a 68 Dart sedan with 13" wheels
and 4 wheel drum brakes.
PostPosted: Fri Apr 01, 2005 5:49 pm
There is, but what's your goal?
PostPosted: Sun Apr 03, 2005 11:05 am
I want to reduce the pedal pressure that I have to apply to the brake
pedal. I know the virtues of disc brakes but I prefer to keep the 4 wheel
drum setup. This car is used a a commuter car and does not see a
lot of hard driving that would lead to brake fade.
PostPosted: Fri Apr 08, 2005 6:52 pm
So SlantSixDan, what is the part? master cylinder and booster.
How will this effect my vacume pressure?
PostPosted: Fri Apr 15, 2005 9:12 pm
Here's one that'll work correctly for you. Hurry fast...
