It is currently Fri Jan 02, 2026 7:42 am
 Post subject: oil in cil 4
PostPosted: Sun Apr 03, 2005 5:36 pm
all cil are good except number 4
my car is running like crap now ...and I got to fix it as soon as possible...
engine block has been resleeved , new rings..og pistons
could this be a broken ring?
bad valve seal
what else could it be?
anyone?
http://www.cardomain.com/id/lncognito
PostPosted: Sun Apr 03, 2005 7:12 pm
bad valve guide, rings didn't break in properly...
Any bad noises? Did you do a compression check?
How do you know there's oil in cyl 4? Are the valves adjusted properly?
PostPosted: Sun Apr 03, 2005 7:16 pm
Cracked head? Was it magnafluxed when rebuilt?
PostPosted: Sun Apr 03, 2005 7:35 pm
I will do a compr. test tommorow
If its rings .... I maybe could get some at napa
or I could order some os pist and rings from Usa and rebore block but it will take about a month for parts to get here
if it guides I do have new ones but I didn't want to use them yet since I got os valves to go with them to build a good head
how do I know... the sparkplug is covered with oil
I've put a adapter for temporary fix....but I need to fix this
 Post subject: For me...
PostPosted: Sun Apr 03, 2005 7:48 pm
this sounds like a bad valve seal, you hear something like a "flap, flap" sound when engine is running?, that happened with a friend´s Mustang.
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
Users browsing this forum: Ahrefs [Bot], curmudgeon, Dutch Dart GT 64, Google [Bot] and 14 guests
