It is currently Wed Dec 31, 2025 11:04 am
 Post subject: vaccum leak?
PostPosted: Mon Apr 04, 2005 2:17 pm
Timing is correct....but still backfiring through the carb under load
PostPosted: Mon Apr 04, 2005 10:59 pm
Have you checked the valve lash? A tight valve can cause that. (tight lash or a sticking guide or a flat cam lobe)
Also a worn distributor shaft can cause the timing to "move around", is the mark steady as you rev up the engine?
