It is currently Tue May 05, 2026 11:36 am
 Post subject: is there a difference
PostPosted: Mon Apr 04, 2005 9:54 pm
Ok I have located several set of front spindles one sbp off of a 69 gts and 4 bbp off of 74 -75 a body's. now my question is, is there a advantage in holding out for a 76 a body ( I understand that the calibers changed that year ) are these a better set up? I plan on buying every thing i can new so does it matter is i grab these spindles from the 75? If i do can i just buy the calibers for the 76 and upgrade that way or is it just as good to get the 75 stuff and go that way
I didn't want to go with the sbp due to the limited wheel choice
also after i upgrade what is the best rear end to look for and what can the rear end come out of something other then an a body that i can get a rear out of?
of ya all this is going in a 69 dart with a 360
PostPosted: Tue Apr 05, 2005 5:12 am
What are you doing here, you traitor? :cry: :evil: :shock:
I will let someone with more knowledge on this answer your question.
PostPosted: Tue Apr 05, 2005 7:00 am
I think they went from Kelsey-Hayes calipers to the sliding type calipers before 1976. My 74 Duster has the sliders.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Tue Apr 05, 2005 2:48 pm
Changes in Federal Motor Vehicle Safety Standards mean that there were THREE different disc brake systems on '76 A-bodies. The strongest brake system is found on those cars built after 1/1/76.
PostPosted: Tue Apr 05, 2005 4:45 pm
Please tell us the details of this "third" brake system. The 1/1/76 date caused drum brakes to be dropped as standard equipment. Actually if I do some digging, I may have the service bulletin about that. Seems I recall it said the drums were dropped mid-December 1975 in preparation for 1/1/76.
Let's see.... 1976 A-bodies changed from the hand operated emergency brake to a foot pedal.
Somewhere I remember reading that the brake pedal ratio was changed on some of the cars too.
I'll have to see if I can dig up that information again.
Gosh Dan, you are still waiting for me to dig up other service bulletins. Was it the one for the ... ummm.... slant 6 carburtor tin plate thing?
PostPosted: Tue Apr 05, 2005 8:31 pm
Craig, I've got a '76 Engineering Overview book from Chrysler that enumerates the stage-1 and stage-2 changes in '76 model brake systems. Stage 1 was in (I think) 10/75, and stage 2 was in 1/76. Unfortunately, that book is with my other 13 boxes of Mopar literature in Denver, and it'll be awhile before it's local to me again, so I don't know for sure.
And yeah, I'm still curious to see that "1 and 6 plate" bulletin, if you get a chance and it floats to the top of the stack. :-)
