It is currently Fri Jun 19, 2026 4:28 pm
 Post subject: spark plug gap
PostPosted: Mon Apr 11, 2005 4:58 pm
what is the correct spark plug gap for a '74 dart with everything stock and a 1 bbl barb. i have a 2.5 exhaust if that makes a difference.
PostPosted: Mon Apr 11, 2005 5:40 pm
0.035" if you're running stock Chrysler electronic ignition.
0.045" if you're running HEI, MSD or BYOB.
PostPosted: Wed Apr 13, 2005 10:47 am
When I ws a kid, BYOB meant 'bring your own booze '. What does it mean now? You can experiment with spark plug gap, and see how it runs with other settings. You might be able to stretch that .035 stock setting out to .040 and see an improvement in fuel economy, or throttle response. The gap gets bigger with time, as part of the electrode burns away, so if you go bigger, you might need to check it more frequently.
69 Dart Swinger, 230 ci slant, t-5 five speed, intercooled turbo, 4 wheel disk brakes, tubular upper control arms.
PostPosted: Wed Apr 13, 2005 7:47 pm
I think in this case it means "facetious". :)
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 1 guest
