It is currently Mon Nov 16, 2026 12:52 pm
 Post subject: /6 with a 727
PostPosted: Mon Apr 11, 2005 3:20 pm
Question: Did Mopar ever make a /6 with a 727 behind it?
PostPosted: Mon Apr 11, 2005 3:23 pm
Yep, the cop/taxi package and some trucks I believe.
 Post subject: 727s
PostPosted: Mon Apr 11, 2005 3:36 pm
Yes, my 69 a100 has a 727 behind it. Well, not right now cause its out getting rebuilt.
PostPosted: Mon Apr 11, 2005 3:46 pm
rIGHT: I had a 72 van that was a phone company van with a /6 225
with a 727...but I thought it was a special order for "fleet" use.
PostPosted: Mon Apr 11, 2005 5:48 pm
My D-150 came from the factory with a 727 behind the slant. Great transmission when combined with the lockup torque convertor, just slips in reverse. Think I might have a loose band
It might have been standard equipmnet for trucks.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Mon Apr 11, 2005 9:19 pm
The early packages had an adapter for mounting a small block 727 to a Slant.
The later trucks and vans had a 727 made for Slants. They came in both standard and lockup. :shock:
PostPosted: Mon Apr 11, 2005 9:31 pm
I have not been able to verify that any 727 trannys ever came with a lock-up torque converter. Can anyone verify this?
PostPosted: Tue Apr 12, 2005 12:52 am
My '83 D-150 has the A833. It's has a shorter bed.
PostPosted: Tue Apr 12, 2005 12:28 pm
I think so. Look in 80s pickups and vans behind Smallblocks until the the A-518 superseded the A-727. What is rare is to find a lockup A-727 with a B/RB bolt pattern. IIRC, that was one year only (1978) and one engine only (400). The 440s didn't get lockup.
PostPosted: Tue Apr 12, 2005 4:16 pm
My 727 definitely has it. You can feel it when the convertor locks up, sorta like it is shifting into a fourth gear.
82 D150-225/727
PostPosted: Wed Apr 13, 2005 7:52 am
I have seen 2 lock-up Slant 727's with my own eyes. Easiest way to tell when one is out is to look at the input shaft. A lock-up will have a pilot on the end like a 4 speed input shaft. :shock:
 Post subject: more re. the lockup 727
PostPosted: Thu Apr 26, 2007 5:11 pm
My parts collection is soon to include a 727 made for a slant six, and the lockup version. I wanna try it in my 64 d100, but wonder the two basics..
Will that input snout go into the existing bearing I previously slid in the '78 crank when I installed an 833OD or do I need to pull the bearing first?
I want a 2,000 to 2,500 lockup convertor with the new Erson cam. I think. Tom McGibbon recommended it in a call. (3.91 posi, truck weight, 28 inch tires) But I can't fine one! Where to get one?
rock
'64d100
PostPosted: Thu Apr 26, 2007 8:37 pm
Try calling Midwest Torque Converter in Rockford, IL. They can probably modify your stock one or build you a new one. :shock:
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
