It is currently Sun Nov 22, 2026 2:43 am
PostPosted: Fri Apr 15, 2005 7:05 pm
Car Model: 69 Dart Slant 6
I'm building a 69 Dart SL6 racer. I want to change the 7 1/4 out to
an A body 8 3/4 741 open 3.91 unit.
Because I will be adding nitrous and want it to hook up,
can I "add" a sure grip to the "pig" and if so
what should I look for.
Understand there were 2 different types of sure grips.
I know the 741 was the weakest 8 3/4 but even tho I'll have
nitrous the car will go 12's max if I'm lucky.
Rick
PostPosted: Fri Apr 15, 2005 8:07 pm
A 741 will survive just fine. There are no "weak" 8-3/4" centre sections. There's "strong", "real strong", and "unbelievably strong".
Two sure-grip styles, and yes, SG can be added to any 8-3/4" centre chunk: Clutch type or cone type. Each has its benefits and drawbacks, so I'll step back and let those opinions be stated.
PostPosted: Sat Apr 16, 2005 5:52 am
Here comes my opinion. Either sure grip unit will work fine, if it is in good condition. The clutch type is easier to repair/rebuild. I have heard the "cone" type can be repaired, also, but not easily. If this will be a drag race only car, you could consider a "mini-locker". The unit just replaces the spider gears, and is less the $100 from Jegs. Don't use it on a street driver.
Users browsing this forum: Bing [Bot] and 11 guests
