It is currently Fri Nov 20, 2026 9:24 am
Post new topic  Reply to topic  [ 32 posts ]  Go to page 1 2 3 Next
 Post subject: msd 6a or 6al
PostPosted: Sun Apr 24, 2005 6:55 pm
what do you perfer for my 1964 dodge dart gt? msd 6a or 6al which is better?
PostPosted: Sun Apr 24, 2005 6:59 pm
the 6al has a built in rev limiter. thats the only difference in the 2 that i know of. its just a matter of choice i guess.
 Post subject: hmm
PostPosted: Sun Apr 24, 2005 7:00 pm
and the 6a is cheaper does the rev limiter make a big difference?
PostPosted: Sun Apr 24, 2005 7:11 pm
Unless you bagdrive your car or floor it in Park you wont need it.
PostPosted: Sun Apr 24, 2005 7:12 pm
Car Model: '23 T-bucket
Does the rev limiter make a difference?....probably only on the dragstrip. It will keep you from over-revving your engine while things are a little "busy" for the driver.
Oh....if you go with a 6A, you can, at a later date, get a plug-in rev limiter attachment from MSD.
Roger
PostPosted: Sun Apr 24, 2005 7:15 pm
What is it that you hope to achieve by installing an MSD?
 Post subject: dan
PostPosted: Sun Apr 24, 2005 7:18 pm
what else do you recomend maybe because im going the whole msd way ?
PostPosted: Sun Apr 24, 2005 7:42 pm
Can't recommend anything until you say what you're trying to improve/change/fix.
 Post subject: Re: dan
PostPosted: Mon Apr 25, 2005 2:29 pm
Why?
 Post subject: umm
PostPosted: Mon Apr 25, 2005 3:11 pm
maybe because everything i have is msd under my hood...
PostPosted: Mon Apr 25, 2005 4:46 pm
Thats a good reason :roll: . There is really not all that much wrong with a Pertronix or Chrysler electronic ignition.
Might be better off spending your money some place else.
82 D150-225/727
02 Dakota-3.9/5 speed
 Post subject: Re: umm
PostPosted: Mon Apr 25, 2005 7:37 pm
:?: Like what???
PostPosted: Mon Apr 25, 2005 7:54 pm
So, Step and others: See what I mean? :roll:
PostPosted: Mon Apr 25, 2005 8:05 pm
well Yeah but before you know it every thread will turn into a flame war and we don't want that. It's very tempting but I would prefer to stick to crayons and grunting.
So sham why do you want to hot rod your car SOOOOOO bad why dont you just FIX it. It did run fine for 40 years you know.
PostPosted: Mon Apr 25, 2005 9:13 pm
Car Model: 1962 Lancer 770
Well you can buy whatever you want from whomever makes it. I have an MSD coil, and it seems fine. But don't simply buy because someone makes it or because "it completes the outfit" so to speak. You seem to be a guy that wants the most bang for the buck, so why not see what other options are out there?
I got electronic ignition for under $70 with all new parts doing the GM HEI conversion.
MJ
Users browsing this forum: Amazon [Bot] and 9 guests
