It is currently Fri May 22, 2026 2:52 pm
PostPosted: Sun Apr 24, 2005 9:02 pm
Tommorrow I am swapping my tranny. I have front and rear seals and a filter/gasket kit. I have experienced help but still anyone have any tips?
PostPosted: Sun Apr 24, 2005 9:27 pm
Use two wrenches to disconnect the oil cooler lines. One to hold the fitting in the transmission, the other to turn the nut on the steel line.
Do not bend, kink, or twist the lines. You can not buy new ones at your dealer.
PostPosted: Mon Apr 25, 2005 8:52 am
Car Model: 1962 Lancer 770
so i'm screwed on the bent ones I have now? oh crap!
Can I make new lines?
MJ
 Post subject: trans lines
PostPosted: Mon Apr 25, 2005 10:58 am
5/16 hardline, tube cutter, double flairing tool, and bending tools and a lot of patience will let you make a replacement line that looks factory.
Regular and stainless replacements are available for reasonable prices from Fine Lines and Classic Tube.
 Post subject: Quick fix
PostPosted: Mon Apr 25, 2005 1:47 pm
If you arn't much of a wiz with a bender, then you can patch back together or just use new mostly straight pieces and some short rubber sections to make the turns.
Be sure to route away from heat or moving parts. Buy the better hose clamps that are designed for fuel injection.(they look better too) Buy the correct rubber line for transmission applications, fuel line will go hard and is a bad idea.
My aspen's cooler lines look very nice this way and saved me a whole bunch of time test fitting.
1980 Aspen 225 super six
