It is currently Sun Jun 14, 2026 5:12 am
 Post subject: Electronic Ignition
PostPosted: Tue Apr 26, 2005 9:39 pm
It looks like I have to re-do my points yet again and I'm sick of it. I'm a neophyte when it comes to this sort of thing, but I am seriously thinking of switching to an electronic ignition system. I've seen the type that use the existing distributor body and wonder if they're any good. I don't have a huge amount of money to throw at the problem, but I sure am sick of changing points. What is the best, most economical way to switch to electronic ignition?
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Tue Apr 26, 2005 9:45 pm
Pertronix
If it ain't broke, fix it!
PostPosted: Tue Apr 26, 2005 9:48 pm
You can get a distributer and ECU from a parts store, and the wire harness from the dealer. Or you can get it all cheaper from a wrecking yard. Either way you want to go, here are wiring diagrams to help you out.
http://www.slantsix.org/articles/elect_ ... wiring.htm
PostPosted: Wed Apr 27, 2005 5:49 am
Pertronix
you mean MSD ?
:LOL:[/b]
Juan Ignacio Caino
PostPosted: Wed Apr 27, 2005 7:30 am
Pertronix
you mean MSD ?
:LOL:[/b]
No, he said he wanted the best, most economical way. I say again - Pertronix.
D/W
 Post subject: Yet another.
PostPosted: Wed Apr 27, 2005 9:27 am
http://www.slantsix.org/articles/leanbu ... rticle.htm
This information is geared to removing the new computer systems, but applys to upgrading from points as well. It actually a bit easier to upgrade from points due to less wiring hassles.
I've done this swap. If you can find a decent distributor on ebay, you can then buy the rest of the parts for about $50 new.
If you can find an old aspen or volare with a slant six, you can rob the entire setup from the junkyard, often for a song.
This is reliable and easy to get parts for. It's also easy to understand for any mechanic who has worked on a few old mopars.
I see it as a good alternative, but 'BEST' is subject to lots of opinion.
'Cheapest' is to get some good quality points and keep them in adjustment.
1980 Aspen 225 super six
PostPosted: Wed Apr 27, 2005 10:23 am
the HEI conversion is inexpensive, easy, better than using the Mopar module, allows bigger spark plug gaps, and eliminates the ballast resistor.
PostPosted: Wed Apr 27, 2005 10:47 am
I spent less on my HEI conversion than the cost of a Pertronix module, using junkyard parts and wire I already had.
 Post subject: Yep
PostPosted: Wed Apr 27, 2005 1:44 pm
I'm not against the HEI conversion. If you are doing all the work yourself and confident with what you are doing, then it's a very good option. (based on the feedback I've seen from other members of this site)
Eliminating the balast resistor makes the wiring simpler, and there are plenty of places to get info, so it's beginning to look like a 'best bet' conversion option. I think most of the parts cost the same or less as well.
Only reason is to stay "all mopar", but all the parts are made in china anyways. :roll:
PostPosted: Wed Apr 27, 2005 3:01 pm
Pertronix
PostPosted: Wed Apr 27, 2005 3:52 pm
I agree. Best and easiest for the money - Pertronix.
PostPosted: Wed Apr 27, 2005 6:42 pm
Does anyone have a part# for an HEI module? The scrap yards in my area seem to be a bit light on Mopars of this vintage.
PostPosted: Wed Apr 27, 2005 6:48 pm
NAPA Echlin TP-45, among MANY others.
PostPosted: Fri Apr 29, 2005 12:35 am
I picked up a distibutor from the junk yard from a /6 truck for $10, the factory wiring harness from the dealer is $20, and the electronic ignition module is $17 from AutoZone. Grand total of $47 and about 1 hour of your time. I've heard good things about Pertronix but the choice is up to you.
70 Valiant Super Six
PostPosted: Fri Apr 29, 2005 7:48 am
There is nothing wrong with any of the options mentioned here. I run (retrofit) standard Chrysler electronic on a lot of my cars, as mentioned, you can score the stuff at the junkyard for cheep if you are lucky. Pertronix cost about 70 bucks including ship, and it takes about 10 minutes to install.
D/W
Users browsing this forum: Amazon [Bot] and 9 guests
