It is currently Fri Nov 20, 2026 4:51 am
 Post subject: Hei swap problems
PostPosted: Wed Apr 27, 2005 6:04 pm
I have an 82 D150 with the lean burn system. The only thing I have left of the system is the dist. and computer. I've changed the coil to an aftermarket coil (Promaster) and it worked fine.
I finally deside to do the full Hei swap and get rid of the computer and dist. I hooked up all the wiring from the coil to the control module to the eletronic dist. No spark.
OK, I change out the pickup coil in the dist and still no spark. I go and have the control module checked out and its bad. Get a new one and had it checked before I left the store and it was good.
Hooked the new module up and still no spark! Did check to see conections were good pos & neg going into module good. No pos & neg electricity coming out of module.
Could someone tell me what I'm missing or what is going on?
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Wed Apr 27, 2005 6:36 pm
Are you sure you're positive to the module is there when you're in the 'Start' position? Sometimes the ignition wire goes dead then. :shock:
PostPosted: Thu Apr 28, 2005 3:59 pm
When the ignition is in the on position I have power going into the hei control module.
