It is currently Fri Nov 20, 2026 8:43 am
PostPosted: Thu Apr 28, 2005 5:25 pm
after taking my carb off the other day, and the fuel inlet needle coming out and putting it back in, now it wont start unless a pour a bit of gas in the carb. Theres a part on my carb i forget what ts called, i just push it down and it puts some gas in the carb. thats the only way i can get it to start real fast, then once i do, it wont start started if i hit the gas (i have to hit it real slowly, and its hard backing upwards out of my driveway, damn hill)
PostPosted: Thu Apr 28, 2005 6:30 pm
Contributor
Did you replace the needle valve correctly? It's easy to reverse it.
PostPosted: Thu Apr 28, 2005 9:12 pm
May-be a vacuum leak.
What is the fuel pressure?
PostPosted: Thu Apr 28, 2005 9:43 pm
Im pretty sure I replaced it correctly. My carbis the 1920. I put the point of the needle pointing outwards from the carb. Im not sure what my fuel pressure is. How can I check it??
PostPosted: Fri Apr 29, 2005 5:06 am
you put the needle in backwards.
PostPosted: Sat Apr 30, 2005 4:48 pm
damn! I checked the choke last night and it was still open in idle so the needle being backwards makes sense now!
PostPosted: Sat Apr 30, 2005 4:50 pm
what the hell!! i did put the point of the needle into the carb........
PostPosted: Sat Apr 30, 2005 11:29 pm
ok, this is &#@% confusing, if i put it in backwards, in another thread theyre saying thats not backwards! And I cant find a photo of all the pieces on the carb broken down.....if anyone has any pictures or know a place....
Users browsing this forum: Google [Bot] and 15 guests
