It is currently Sat Jan 03, 2026 4:32 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Wed Apr 27, 2005 6:23 pm
Update, the green bearings and 3.91's have been installed. The rear is sooooo much quieter now, and it really jumps when you hit it. I can feel it is much quicker now but I have lost much top end. These gears will come out a couple days after the MOPAR nats on the 14th, there is no way I could afford the gas to keep them in.
PostPosted: Sat Apr 30, 2005 6:17 pm
Ok this is how I spent my saturday
First we emptied the engine bay
paintad some accessories
my wife painted the intake
mounted the fan to the rad
then installed the engine Thanks Dan, this it the famous brother in law I have been talking about I'm the 4-eyes on the right.
and a better shot of the engine mounted in the car
there is still a lot of work to do I still have to install the starter, intake, headers, carb, fuel pump, rad, trans inspection cover, power steering pump, alternator, waterpump pulley, belts, and pick up more heater hose. I expect to drive it to work on monday.
 Post subject: update
PostPosted: Sun May 01, 2005 1:20 pm
It's in and running like a bear! It has a totally different exhaust note as well. I'm going to have to wait until tuesday to adjust the valves, they clatter a little bit but it idles great and pulls harder throught the entire power band. I'm really pumped.
one of the proud father and car
PostPosted: Sun May 01, 2005 2:15 pm
Great! :D
PostPosted: Sun May 01, 2005 6:19 pm
Good job. My brother and I got my motor and transmission back in my car today. I just have a few more things to do before I can get it running again. Hope I'm as happy with my end result as you are.
 Post subject: Good Work
PostPosted: Mon May 02, 2005 9:52 am
I know that was a lot of work.
Looks great!
It's the fabled 2 day motor swap, but in real life!
You've really got to have your s**t together to get it done that quick. And you got pictures!
1980 Aspen 225 super six
PostPosted: Mon May 02, 2005 12:13 pm
WOW THAT LOOK'S GREAT !!!!!!! :lol:
PostPosted: Mon May 02, 2005 5:16 pm
whadafuck I can't see those pix and you guys telling how great it looks are making me anxy. I wanna, musta see those pix
Juan Ignacio Caino
PostPosted: Mon May 02, 2005 6:13 pm
something must be wrong at village photos I cant see them any more either
PostPosted: Tue May 03, 2005 6:29 pm
Looks awesome, Phil - great job. Hook it up and rip!
PostPosted: Wed May 04, 2005 6:05 pm
The pics are working again!
I spent a little time under the hood tonight adjusting the valves. They were ALL loose. I got my old low rumbly exhaust note back, it was really rappy with the valves loose. the engine its self was tappy as well.
I also checked the compression the are all at 155-165 psi. I left the timing alone at 8* before top dead center.
one thing that bothers me though is the oil light comes on at idle. not always, it didn't come on at all this morning but this evening it did. Apparently the old sender didn't work because the oil light never came on before. I thought the bulb must have been bad. I guess I'll have to try a thicker oil, I'm using 10W30 right now. OR I could just bump the idle up a bit in drive. The light comes on only below 650rpm.
