It is currently Fri Nov 20, 2026 9:56 pm
 Post subject: 68 air cleaner on a 73
PostPosted: Sun May 01, 2005 11:36 pm
can i take a 68 air cleaner on a 73. and would there be a diffenance in power?
PostPosted: Mon May 02, 2005 6:39 am
Yes.
No. (well, you'll probably get a .0001% increase in hp.)
D/W
If it ain't broke, fix it!
PostPosted: Mon May 02, 2005 7:29 am
You'll have to plug off the air cleaner vacuum line on the '73 carb, and your cold-weather driveability may suffer some, depending on what kind of climate you live in.
And no, there wouldn't be a difference (improvement) in power.
PostPosted: Mon May 02, 2005 3:42 pm
i live in California so i't mostly warm at here year round.
another thing i was wondering about was on a 60's ir cleaner not sure what year for to be exact. On the bottom plate it had a vaccum line running form the exuhaust manifold to the air cleaner. so any one know the deal with that. I didnt get that one was just wondering about it.
I love them juck yard. just like a truasure hunt you never know what you can dig up.
PostPosted: Mon May 02, 2005 7:32 pm
That would be a '69, with the one-year-only* carburetor anti-ice system. It channels air from the clean side of the air filter, via a rubber hose, through a steel tube that passes through the #2 runner of the exhaust manifold, to a fitting at the base of the carb. This feeds heated air to the underside of the throttle plate to prevent ice-up. It's largely unneeded with today's fuel formulations and tends to make hot-weather problems (carb boiling). The '70 introduction of the thermostatic air cleaner was a much, much better solution.
* - This system was available in Canada from '61-'69, but was only used in the US in '69.
PostPosted: Tue May 03, 2005 5:57 am
Flip your air cleaner lid upside down.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Tue May 03, 2005 3:36 pm
All that does is make more noise.
PostPosted: Tue May 03, 2005 3:40 pm
...and that's a bad thing??? :lol:
D/W
PostPosted: Tue May 03, 2005 4:23 pm
Got me a ticket once! (On the other hand, it got me *out* of a bigger ticket at the same time...)
PostPosted: Tue May 03, 2005 4:36 pm
I like running a taller than stock element for Baaahgability. Looks more pro-feshunile than a flipped lid! :lol:
D/W
(8:1)400 + 750AVS + 2.76:1 = BWAAAAAAAAAAAAAAAAAAAAAAAH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :shock: 8) :lol: :D
PostPosted: Wed May 04, 2005 11:07 am
how about one of those little single barrel air filters? you know the really small one like two inch. i put one on just for fun and well i'll i could here was air being sucking in. you know know some like SSSSSSSSSSSSS
PostPosted: Wed May 04, 2005 2:11 pm
Those tiny little open element air filters clog up very quickly, due to their small size. Open element filters are not a very wise choice either. You'e best bet is to rig up some sort of cold air intake system.
Hey Dennis, that big Newp has 2.76 gears :shock: :!:
and what is BWAAAAAAAAAAAAAAAAAAAAH!!!!!!!!!!!!!!!!!!!!!!!!!! :?:
82 D150-225/727
PostPosted: Wed May 04, 2005 3:44 pm
Lotsa big-block C-bodies do, that's how them big ol' battlestars reach light-speed so easily :D I'm leaving the 2.76's in my '66 Polara when the new 440 goes in... until I save up enough for a gear-vendors overdrive anyway :-)
The sound of the secondaries opening up when you floor a big-block with a Thermoquad! Dennis said AVS, but compared to a TQ an AVS is "bwaaaaaaaaaaaaaaaaaahhhh!!!! " at best! :P
PostPosted: Wed May 04, 2005 3:53 pm
...I gets by. 8)
D/W
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Google [Bot] and 5 guests
