It is currently Wed May 06, 2026 9:44 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
Do you have disc brakes?
Don't have, but planning to get. 41%  41%  [ 13 ]
Don't have, and NOT planning to get. 16%  16%  [ 5 ]
Got em' and love 'em. 38%  38%  [ 12 ]
What are disc brakes? 6%  6%  [ 2 ]
Total votes: 32
PostPosted: Wed May 04, 2005 3:34 pm
You need some grease on the pads!
I have never heard a cop complaining about too good brakes...
PostPosted: Fri May 06, 2005 4:41 pm
My '65 Dart has the disk brake setup from a '75 Dart SE. The rear brakes are also from the same car. The master cylinder is a 2 bolt aluminum set up from a '80 Volare with manual disk brakes. The proportioning valve is from a disk brake '73 Dart. The car stops straight and true, a vast improvement over the OEM 9' brakes.
PostPosted: Fri Jun 03, 2005 10:19 pm
Yep, I swapped on some disc brakes onto my '65 also. I went with the bigger version.
Users browsing this forum: Amazon [Bot] and 1 guest
