It is currently Sat Nov 21, 2026 8:01 am
 Post subject: Heater hose question
PostPosted: Fri May 06, 2005 10:38 am
I did a complete search on this question and didn't come up with a definite answer.Can anyone answer this?
Which side does the water pump hose go to the heater core?
If you have the answer can you explain it like this.
When standing in front of the car the water pump goes to the passenger side or the drivers side of the heater core.
Thanks JZ
PostPosted: Fri May 06, 2005 10:51 am
Differs by model, year and with/without factory A/C. WHat are you working on?
PostPosted: Fri May 06, 2005 11:51 am
Or, like on my '74 Dart Sport, it is self-evident....
One is 1/2" and the other is 5/8". :wink:
Jerry
PostPosted: Fri May 06, 2005 12:48 pm
Dan,
65 Dart 225
Not sure what year the block is,but I believe it to be a early block & head if that helps.
Thanks JZ
PostPosted: Fri May 06, 2005 12:49 pm
No a/c
65 Heater core
JZ
PostPosted: Fri May 06, 2005 4:09 pm
It dosen't matter which way the hoses go.
PostPosted: Fri May 06, 2005 6:45 pm
In a '63-up A-body, no, it doesn't matter as far as heating capacity is concerned. But getting the hoses swapped frequently causes annoying noises in the heater system. There's a '66 TSB on the subject, with the same "how to hook up the hoses" diagram that's in the FSM, but it's at my office and right now I'm not.
PostPosted: Sat May 07, 2005 4:25 pm
Cool Dan,
Look forward to that info if you can.
Thanks
JZ
PostPosted: Sat May 07, 2005 4:34 pm
JZ-
I'll dig for the TSB, but...
...butbut...
...couldn't you just look in your FSM?
(Did I catch you workin' on your car without the FSM???)
-DS
PostPosted: Sat May 07, 2005 5:06 pm
Dan,I have three different manuals but none of them are a fsm. :cry:
I have been looking for pics etc bot to no avail.
Some say it doesn't matter,and some have said there is a proper order.Just trying to find the proper order before I button this thing up.
Thanks JZ
