It is currently Sun Jun 21, 2026 2:38 am
PostPosted: Sat May 07, 2005 6:33 am
Hi folks. I have had some great success with my fuel injected turbocharged Slant 6 using low comp dished cast pistons... I have had 20 lbs boost into these suckers and they are showing a greeat resistence to the beeating I have put them through. I am now on the hunt for serious power out of my Slant and have been looking at forged piston alternatives.
Has anyone used VW flat four pistons with any success ? ... I have just ordered a set of 88mm mahle forgings and another experimental set of 90.5mm. From what i have researched the compression height is slightly lower on teh 90.5mm piston... this may very well require sleeving for use but a 4.0 litre Slant sounds like a good thing. :) For now I will be using the 88mm items with 198 rods, they are a floating piston also but so far all is looking pretty positive.
Any thoughts on this would be great.
Ray.
PostPosted: Sat May 07, 2005 9:21 am
I believe the fin (Jyri?) used vw pistons?
PostPosted: Sat May 07, 2005 3:40 pm
Now, Ray, I'm not gonna accuse you of anything, 'cause that wouldn't be neighbourly, but if I were, I'd probably say it sounds a lot like you're bragging, mate! :-D
Seriously, keep posting the good stuff on your car. It's great to see.
PostPosted: Sat May 07, 2005 4:06 pm
Car Model: 69 Valiant 225, 70 with a 265, 70 with a 318
After seeing Ray's car up close a few times I think he has every right to brag about it (not that he does)
It's a very tidy unit with a lot work and $ in it. I will watching with interest to see how it runs on the 1/4 with the next build. 8)
Richard (aka Fingers)
PostPosted: Sat May 07, 2005 4:19 pm
DEFINITELY!
 Post subject: Pistons ..?
PostPosted: Sat May 07, 2005 6:51 pm
Thanks for your replies....
Dan : No not bragging, I just think it's incredible how well these pistons are holding up... and when I said "great success" I was really paying homage to the greatness of our beloved Slant 6 engine and it's willingness to be boosted ! I am but a newbie to the Slant 6 phenomenon, only six years young...but hooked like all our SL6 junkie bretheren. :)
I have had many conversations with Jyri, he has been of great assistance even though there is an obvious language barrier. In fact I purchased my 198 rods off him recently already bushed to accept the VW gudgeon. Now that I have these rods I have had the opportunity to research the viability in remanufacturing them... as it turns out i can have them made but as with most things they are quite costly @ around $1500 AUD per set.... but they will be almost bullet-proof. More on that later.
I would like to know if there has been any other recorded use of these pistons as an alternative for the lack of forgings for Slant 6 engines. This is the avenue I have chosen to take with my new build and i will definately advise of outcome, power figures, 1/4 mile times and most importantly to me driveability.
My car is my daily driver, but I still love having fun in it. This is the second engine I have built for the use of injection/turbo, the first one suffered from serious cam-walk, which I never before seen on a Slant, but is an inherent problem with our Hemi 6 engines here in Oz. With this current engine I have taken measures to ensure that problem is resolved. The first build was really a test bed for the basics... still made pretty good power for a "throw-together" @ 220 rwhp and a copius amount of torque. It was all junkyard peices really, modified and tidied up to look the part...fancy that it made really good useable power. :) It has not been shy of it's fair amount of issues though...a blown head-gasket during burnout comp and my current setup has shown obvious flaws in air distribution, I have problems with the front throttle body leaning out....once seizing #1 exhaust valve open.. ( again during a burnout comp )... but other than that it has been fairly reliable, considering the hard time it gets...
I havent really spent much time here on this board as I am pretty tied up with my own Australian based web presence ( http://www.moparmarket.com).... but if it's ok with you guys, i'd love to spend more time here from time to time....
Oh, by the way I also have a restoration business here in Sydney that specialises in the preservation of Classic Mopars, we manufacture components to assist in the restoration of these cars... I mention this because we are currently making an intake manifold for the Hemi 6 that is very simliar to the Hyper_Pak Slant intake....this will be complete in around 6 months time, we are then going to make a 4 barrel intake for the Slant, very similar in design to the Hyper-Pak but incorporating injection facilities also.... just thought you folks might like to know about that as info comes....
Thanks.
Ray
 Post subject: Re: Pistons ..?
PostPosted: Sat May 07, 2005 7:16 pm
Well, why not? You should be! Your work on the Val is stunning.
Yes, more later please! 198 rods are getting tough to source.
Nightly, too? You should have a set of these, compared with standard sealed and H4 items here. The ones on my site are wrong-side-drive, but I can get you the P/Ns for RHD.
Yes, please do!
Whom do you like for repro lenses? I'm talking with someone in OZ about '62 Lancer lenses (not Azzopardi; don't like his stuff).
Nifty stuff, keep it comin'.
(How 'bout an alloy head w/newer-than-stone-age combustion chambers for the slant...?)
PostPosted: Sat May 07, 2005 11:55 pm
Car Model: 1964 Valiant
If cast pistons handle 20 pounds you're doing something
right. I don't think diesel truck motor pistons would last
long should serious detonation occur. 20 pounds is a lot
of boost.
 Post subject: Pistons...
PostPosted: Sun May 08, 2005 6:13 am
Yeah, i would not have thought the pistons would hold up to this kind of abuse either.... I have damaged number 6 after I blew the head gasket ( it blew from cylinder to rear tappet gallery. ) but I am guessing that was from driving it home afterwards, even if I was crawling. It has minor pitting in the top of the piston now, but I replaced the gasket and bolted the head back on to see how it would go. I am very impressed. These pistons are no longer available but was fortunate enough to buy two 0.40" sets a couple of years ago cheap from a closing dealer just labelled "Slant 6 truck". I recently found another set at a swap meet for $80 ! .... I love these things.
Also, has anyone tried fitting wet sleeves for larger replacement pistons.... I am thinking of these 90.5mm forgings for a wicked 4001cc normally aspirated Slant monster. Thoughts ?
 Post subject: Re: Pistons...
PostPosted: Sun May 08, 2005 7:56 am
You may well run into trouble with the single-thickness wall that separates the camshaft from the bore area...this is what doomed the plan to increase the slant to 246 CID in '67; the beancounters nixed the block casting rework.
PostPosted: Mon May 09, 2005 7:06 am
Lots of racers are boring up to 0.130-0.140" over (sonic check) and some running without block filler. 0.100" over is very common.
Still won't get you 90.5mm, but just some info for ya.
