It is currently Sat Jun 20, 2026 12:01 pm
Post new topic  Reply to topic  [ 31 posts ]  Go to page 1 2 3 Next
 Post subject: Knock knock oh crap!!
PostPosted: Sun May 08, 2005 10:57 am
Fired up my new 225 aluminum slant this week. Got a nice Dutra dual exhaust system installed. 500 edelbrock carb. Offy aluminum intake. Idles good but upon acceleration I`m getting a knocking noise from the engine and it sounds like its close to the #1 or #2 cylinder. 35 psi oil pressure. I know this is brief but I have all new parts inside and out. I wonder if the lifters would knock like this if they are out of adjustment? It does not knock when idleing maybe its the timing? Who knows????
PostPosted: Sun May 08, 2005 11:16 am
Car Model: 1962 Lancer 770
not by chance the new aftermarket fuel pump? I guess you'd hear that at idle as well as under throttle. =(
I was just looking for a "don't worry" solution ;-)
 Post subject: knock, knock....
PostPosted: Sun May 08, 2005 11:31 am
sorry, i couldn't help myself. two thing i would do, adjust valves and check timing/vacuum advance.
PostPosted: Sun May 08, 2005 12:43 pm
Need more info on the "knock" sound. Can you compare it to something in tone and volume?
Spark advance and valves -- no. Those don't really make "knocking" sounds at idle.
PostPosted: Sun May 08, 2005 1:03 pm
Just asking about something I have no idea about...
Didn´t some aluminum /6´s have some trouble with the cam "walking"???
Could it be something like that?
Just an idea...
PostPosted: Sun May 08, 2005 2:17 pm
The cam setup's the same in the aluminum and iron blocks; no real systematic walking issues.
One question for Lancergt: Which way round did you install the conrods? Oil hole pointing towards...?
PostPosted: Sun May 08, 2005 5:05 pm
Connecting rod oil holes are pointed away from the cam. (Pointing toward the drivers side). Almost sounds like a rod knocking if that helps anyone. Does not sound like a valve to me. It is coming from down in the belly of the beast.
 Post subject: ?
PostPosted: Sun May 08, 2005 5:15 pm
I had a tork come lose one time on me,and it sounded
like a rod knocking. It also was there when I hit the gas
but not there at idle..
PostPosted: Sun May 08, 2005 5:44 pm
What is a tork?
PostPosted: Sun May 08, 2005 6:37 pm
A resident of Torkey, also known as Torquey.
PostPosted: Sun May 08, 2005 7:58 pm
Good, that's how they're meant to be in the aluminum engine. It does sound as though you're looking at some fairly large reworking, I'm afraid...
PostPosted: Mon May 09, 2005 6:45 am
Could a bad harmonic balancer produce a knock? Seems odd that the knock only happens with an increase in speed. Just a thought.
PostPosted: Mon May 09, 2005 7:59 am
No, there's really no way the harmonic balancer can go bad that could cause a knock. But you may want to recheck your flywheel (or flex plate) attachment to make sure it's correct.
PostPosted: Mon May 09, 2005 12:40 pm
That depends... I had a 440 that developed a horrific knock within a few minutes of first-start one time. I was ready to tear into her again but it turned out to be simple: I'd used an aftermarket fluid-type damper, and the bolts were *just* long enough to rub against the timing chain cover.
The knock happenening with an increase in speed could mean many things, though. It could be a connecting rod that only gets loud when the centrifugal forces get high with increasing speed.
PostPosted: Mon May 09, 2005 12:42 pm
Basil, Cybil, Polly, or Manuel?
Does that make it a Fawlty Tork? :P
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
