It is currently Fri Jun 19, 2026 4:27 pm
PostPosted: Mon May 09, 2005 6:42 pm
Do you need to seal the bolts for the alt bracket that go into the block.If so what do you use to seal it.
It seems as though some oil is leaking around that area.
Thanks JZ
 Post subject: leaky
PostPosted: Mon May 09, 2005 6:46 pm
Car Model: '63 Dart GT Convertible
My Duster always had a pool of oil around the alt. bracket, until I changed the valve cover gasket. The bolt needs no sealant.
ifyoubegintothinkyou'relosingcontrol...it'salreadygone
PostPosted: Mon May 09, 2005 7:01 pm
One or two of the alternator bracket holes into the cylinder head go all the way through to the inside and sometimes leak oil if not sealed. Use some Permatex type stuff or (ugh) RTV silicone on the threads.
PostPosted: Mon May 09, 2005 8:52 pm
Never got that problem, but meaby you can use some black silicone, that solves almost everything.
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Mon May 09, 2005 10:48 pm
I used teflon tape for those two bolts.
PostPosted: Mon May 09, 2005 11:24 pm
So you do have to seal those 2 bolts,that is what I thought from the oil on the bolts.Sounds like some teflon tape will be the ticket.
Thanks
JZ
PostPosted: Tue May 10, 2005 4:53 am
I stand corrected, I've not had that problem so never new tape could be used.
PostPosted: Tue May 10, 2005 7:54 am
I left the bolts out of those holes when I switched the alternator to the driver's side. It makes a BIIIIIIGGGGG mess. :shock:
PostPosted: Tue May 10, 2005 8:01 am
I left those bolts out when I switched to my dr side alt and surprisingly it was only a small mess. About 1 qt every 500 miles or so. Weird.
PostPosted: Tue May 10, 2005 9:14 am
So if someday I decide to switch my alternator to drivers side, I can use my original brackets?, I was thinking to switch it to drivers side to make more easy to put a A/C system in my car, so I can put A/C compressor in alternator place and get a more easy and clean operation.
Valiant Duster 1971
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
