It is currently Tue Oct 13, 2026 4:57 pm
 Post subject: pushrods
PostPosted: Thu May 12, 2005 1:58 pm
1975 head and block, had a ton of work done to the head so lift is now .531 (for the clifford cam).
will regular length pushrods now be worthless?
is chrome moly worth it?
PostPosted: Thu May 12, 2005 3:12 pm
How much have you shaved off the deck or head? That determines if you need shorter PRs. Cam has only a small effect.
PostPosted: Thu May 12, 2005 3:22 pm
.090 has been shaved off.
PostPosted: Thu May 12, 2005 3:23 pm
.090 off the head that is, the block was decked, .006
PostPosted: Thu May 12, 2005 3:28 pm
Stock Pus Rods will work there. I had to go to shorter ones when I had taken 100 of the head and block.
PostPosted: Thu May 12, 2005 7:14 pm
so, a .010 difference from .090 made you have to shorten the rods? that makes me think I might need to get shorter ones now.......
how much shorter than stock did you go?
PostPosted: Thu May 12, 2005 7:15 pm
or did you mean .100 off of the head AND the block (as in each instead of grand total)? I am not sure what you mean.
PostPosted: Thu May 12, 2005 8:14 pm
Actually you need to wait until you have the head and block assembled to see where your rocker arms hit the valve stem tips. Before that time, anything is just a guess. :shock:
PostPosted: Thu May 12, 2005 8:20 pm
I would say a rule of thumb is that anything up to about 0.080" shave and you're safe, BUT I agree with Dennis that you really need to measure to get it right.
PostPosted: Fri May 13, 2005 4:22 pm
SL6 Racer
You still might be OK.....also depends on the base circle of your camshaft.
I would do a mock-up and see where you're at. Also if you have installed valve spring with more spring pressure you might want to think about after market push rods. I found out the hard way.
PostPosted: Fri May 13, 2005 7:04 pm
I never got shorter push rods. I have 0.100" of the head and a mild cam. there is still plenty of room for adjustments to the rockers.
PostPosted: Sat May 14, 2005 5:52 am
I was planning to use the clifford rods, is chrome moly worth the extra cash?
the head work was designed to fit the clifford cam of .531 lift.
PostPosted: Sat May 14, 2005 6:04 am
I would say you "need" thicker pushrods, (and maybe shorter...)
They are awfully long and thin...
Just if the stock ones are too long :wink:
PostPosted: Sat May 14, 2005 7:28 am
any recomendations to brand and length?
PostPosted: Mon May 16, 2005 3:41 pm
any last minute recomendations?
I am putting her back together this week.........
Users browsing this forum: DuckDuckGo [Bot] and 7 guests
