It is currently Sun Nov 22, 2026 9:50 am
PostPosted: Sat May 14, 2005 8:01 am
I have a head I am building for my 81 D100
As best as I can tell this truck was a patch totogeatherhen I got it. It has a
5 freeze plug forged crank block (tapered water pump rib) with a super six
setup on it. It currently has a "peanut plug" head and a points dist. Defedefenitly original. Any way I have a "tube" head that I have had laying around
and is there some way to measure it to see if it has ever been shaved?
I was thinking maybe measure from the valve cover mating surface to the
head surface. The chambers dont loodon'tke they have ever been touched,
but arent quiaren'tund either. Oh the joy of figuring out what the previous
owners have done. by the way the casting # on the head is 2206035-4
if that matters.
Thanks
85 D150 318
85 D350 360
85 Ramcharger was 318
77 Plym Volare 225 904 (derby car)
66 D100 225 3spd
64 D100 225 3spd
81 D100 225 727
90 shadow 2.2 5spd
92 shadow 2.2 5spd
http://www.freewebs.com/ramcharger/
PostPosted: Sat May 14, 2005 8:14 am
I wouldn´t count on every head being the same height from the factory, so I guess you have to cc. the chambers, and see what compression you get...
PostPosted: Sat May 14, 2005 1:16 pm
I know it is probably here somewhere but I could not find it. What should
an uncut stock head cc at. also what should the installed valve springs
height be and how many pounds should they be at that height. the reason
I am worried about the valve springs is the engine this head came off of had
a rod through the side so Im sure it was twisted hard. by the way all of the
springs are green, did dodge ever do that? anybody know about intake
valves having 3 grooves and exh only having 2 grooves?
it really has been to long since I have messed with a slant but now I have a
few :D
thanks for any light anyone can shed on this
85 D150 318
85 D350 360
66 D100 225 3spd
64 D100 225 3spd
81 D100 225 727
90 shadow 2.2 5spd
92 shadow 2.2 5spd
PostPosted: Sat May 14, 2005 1:26 pm
The chamber cc......Depends... You have to measure them...
The spring installed height should be 1-11/16" OR 1-21/32" depending on the year...
The green springs are probably stock...
The 3/2 groove valves are normal...
