It is currently Mon Jun 15, 2026 4:04 am
 Post subject: super six fired right up
PostPosted: Sat May 14, 2005 7:08 pm
Hey 70valiant, my camo'd 85 d100 is now a super six. Had it on the road and already feel a big improvement.
Next I gotta get her to the muffler shop to do away with that 1 7/8" pipe. I have everything from the cat back at 2 1/2" with a turnout just before the rear tire. But it looks like there isn't enough room between the manifold bolts for 2 1/2" so I'll go with 2 1/4"
I still have to tweek a few things engine wise. I now have a few extra vacuum lines left over. There are less ports on this BBD carb. I doesn't seem to affect the engine so far.
Any opinions? Should I rip them out or get some splitters to hook them up to the carb?
There is no problem that cannot be solved by the proper application of thermo nuclear weapons
PostPosted: Sun May 15, 2005 6:30 am
Yep, 2.25" pipe is the biggest you can run on a stock exh manifold.
Great work - keep it up!
PostPosted: Sun May 15, 2005 8:24 am
What to do with them depends on what they are (where the other ends of these "extra" lines are hooked up).
PostPosted: Sun May 15, 2005 9:08 am
I have 2.5", but I cheat... :wink:
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 2 guests
