It is currently Mon Oct 12, 2026 12:17 am
 Post subject: new carb
PostPosted: Thu Apr 21, 2005 2:32 pm
my old 390cfm carter craped out on me i'm replacing it on a new reman. will i have to change out the jets to get it to run good? what is the diffrence in installing a afb or a edelbrock. a 500cfm is almost 200$ cheeper will i have problems with it?
I don't know that mutch about carbs thanks for any help
PostPosted: Thu Apr 21, 2005 3:02 pm
What's a 390 carter? Did you mean a holley?
There is no difference in an AFB or an Edelbrock, same carb. Not sure if they come jetted differently in 500 form, there may be some proprietary differences by brand. Both carbs are manufactured side by side at the same plant.
D/W
If it ain't broke, fix it!
PostPosted: Fri Apr 22, 2005 12:04 pm
it's a carter 9000 series i was told model 9410 is a 390cfm
thanks dennis
PostPosted: Fri Apr 22, 2005 12:58 pm
That's a 400cfm carb, but close enough... :lol: I'm pretty sure those aren't available anymore. ...wanna sell your old one?? :D
D/W
PostPosted: Fri Apr 22, 2005 1:41 pm
gas is pouring out the bowl vent I think it was bought in 83 and rebuilt in 89 it's not in the best shape I think it's fixable. I cant get it to stop gushing out gas. i'm in washington I don't know that shipping costs? what do you want to pay?
PostPosted: Fri Apr 22, 2005 2:11 pm
Sounds like it needs floats. :shock:
Carters and Eddys are not identical. There are some differences, but not much. :D
PostPosted: Fri Apr 22, 2005 2:46 pm
Please tell.
Thanks,
D/W
PostPosted: Sat Apr 23, 2005 7:56 am
The label riveted to the air horn. One says "Edelbrock" the other says "Carter AFB".
PostPosted: Sat Apr 23, 2005 5:51 pm
That's what I say. :lol:
D/W
PostPosted: Sun Apr 24, 2005 5:07 am
I bought an Edel 600 and a Carter 500. Far as I can tell they are the same carb except for jets/rods, and the 500 has a larger discharge ring setup (screwed on and removable) in the primary barrels. Looks like you could convert 500 to 600 and vv with that part.
PostPosted: Sun Apr 24, 2005 10:21 am
Hey, if Dennis doesn't buy this 390 CFM carter, I will! Please let me know if it is still available. Thanks!
PostPosted: Sun Apr 24, 2005 11:05 am
I think you're right, Lou. I also think we can make an AVS 500 if we put the new-style AVS top on a 500 and lose the weighted air door.
D/W
 Post subject: it too this long to get.
PostPosted: Thu May 19, 2005 11:46 am
I got my ups finally and hooked up the 500cfm and i cant get the idle lower than 2000+ I don't have a tac so i don't know what its at butt its way too high it runs with no misses when the set screws all the way out and when i unplug the vac add it makes the idle a little slower
Do I need smaller jets?
Rick
PostPosted: Thu May 19, 2005 11:54 am
Car Model: 1964 Valiant 2dr post
If it won't run below 2000 rpm then its a huge vacuum leak...probably the PCV port or a large gasket mismatch.
Everytime I've had an engine that wouldn't idle below that high an rpm it was a big v leak.
The Carter 400 competition carbs are excellent, I used t run two on a dual quad years ago...that said, I'm not a big fan of Carter/Edelbrock carb design in general. But the small 400's were an good solution for dual carbs on a big V8. And tthe 500-600 cfm models run well in general but often have off idle stuble problems due to a poor accel pump system design.
I've built at least 100 of these over the last twenty years.
Karl
64 GTO...10.80's@122 on street radials
Destroked 455, Qjet, stock ign, 2400 stall
64 Valiant
Old 225, 4spd, 2.92-8.75, 2bbl, headers
dual 2.25"
PostPosted: Thu May 19, 2005 9:18 pm
How many cfm got a Holley 1920? also anyone had hear about a carburetor from Power Motor´s brand?
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
Users browsing this forum: Amazon [Bot] and 15 guests
