It is currently Wed Oct 14, 2026 1:12 am
 Post subject: 500 eddy
PostPosted: Thu May 19, 2005 10:06 pm
I just got my new carb hooked it up my idle is way too fast even with the set screws all the way out.
what do I do to test my PVC valve?
has any one bolted a 500cfm on a stock engine(i have headers and a cain 4brl intake) and have it work ok?
my other carb was gushing out gass and was old and nasty so i replaced it do fuel pumps ever put out to much fuel?
any one? please any one!
Rick
PostPosted: Thu May 19, 2005 10:25 pm
To me, it sounds like you have a vacuum leak. Are all your hoses and everything connected in the right places?
Is your new intake bolted up properly to the head?
Your old carburator was probably gushing out fuel because your needle was stuck, I've had this happen to me. Your fuel pump, if it is stock, does not put out a lot of PSI.
Your PCV valve should rattle around when you shake it. If it is not working properly, it might be the source of your vacuum leak, and may cause your car to idle improperly.
Does your idle slow down when you put your finger over the hose that goes to the PCV? If it slows down a lot, it probably means that your PCV valve needs replacing.
You can try and clean your PCV valve with carburator cleaner. But it's probably just as easy to buy a new one.
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
PostPosted: Fri May 20, 2005 8:49 am
thanks for your help i will check it out today and let you know. If I remenber right my pcv did move when I wiggled it.
I have not messed with my intake so i think it is ok
thanks
PostPosted: Fri May 20, 2005 1:42 pm
So I took off the carb and replaced the pcv re tightend every thing back down and that fixed the leek
Users browsing this forum: DuckDuckGo [Bot] and 5 guests
