It is currently Tue May 19, 2026 8:38 am
 Post subject: Wheels
PostPosted: Fri May 20, 2005 6:49 am
I have a chance to buy some 16 " x 6.5" 5 spoke aluminum wheels off a 2003 Stratus with some 205 60 R16 tires. Will these fit in a 64 Dart that has 73 Duster front discs and rear drums?
PostPosted: Fri May 20, 2005 9:29 am
What bolt pattern are they?
Is a stratus a front wheel drive car?
More than likely the back spacing would be way off.
The best way to tell would be to try and put one on.
.02 get some steelies or rallye's or cragers and call it good.
JZ
PostPosted: Fri May 20, 2005 10:20 am
No. Front-wheel-drive wheels do not have the correct offset to be used safely on a rear-wheel-drive car, even if the bolt circle were correct.
PostPosted: Fri May 20, 2005 10:58 am
Thanks! I didn't know that.
I think the earlier A bodies would look good with the look of thes Stratus type cars though.
PostPosted: Fri May 20, 2005 11:32 am
Just went to a custome wheel website and I understand the FWD/RWD thing now.
Is there any way to get close to that look safely?
