It is currently Thu May 07, 2026 1:47 am
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Fri Apr 29, 2005 11:19 am
I found this book helpful as well:
http://www.moparpages.com/suspension_book/
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
PostPosted: Fri Apr 29, 2005 8:05 pm
In my opinion, old cars handle pretty good. My Duster has bone stock suspension with no sway bars or anything. Yet it is still an easy and fun car to drive.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sat Apr 30, 2005 6:22 pm
Car Model: 1962 Lancer 770
Absolutely, its a great resource and I highly recommend it to anyone. Problem is, the addco bar is the only one that he talks about directly, and I've only seen one mounted the brackets hung below the K member just begging to be hit on something like a speed bump or something.
Do you have one mounted on the dart? I'd be interested in pictures.
MJ
 Post subject: Sway Bar?
PostPosted: Tue May 03, 2005 11:37 pm
Firm Feel offers excellent front and rear bars:
www.firmfeel/swaybars_a.htm
PostPosted: Wed May 04, 2005 7:46 am
yes i've been chatting with them about their bars. They look like they are well made, have very good mounting vs. the addco setups, but they are atleast $100 more.
Have you used these bars and if so on what application? I'd love some personal experience info on them.
MJ
PostPosted: Wed May 04, 2005 8:05 pm
If you are not into fabrication much, I would say $100 more is about right for the FF sway bars with good mounts. The Addco mounts take a good amount of work and welding to make them right. Everything I've heard about FF products has been quite good.
PostPosted: Wed May 04, 2005 8:10 pm
Mmm, yummy...new source of sway bars...
PostPosted: Wed May 04, 2005 10:06 pm
I've installed the Firm Feel sway bar on my 1963 Dodge Dart GT convertible.
The car's not on the road yet. I'm still putting it back together after it spent 30 months in a body shop having all the rusted sheet metal replaced and first class paint applied.
I also installed Firm Feel's K member, boxed lower control arms, tubular upper control arms, the 11/16" seamless tubing tie rod kit, polyurethane bushings, greasable lower control arm pins, Edelbrock IAS shocks, and the Mopar Action 11.75 disc brake conversion with Wilwood calipers.
In the next couple of weeks, I'll install the A body 8 3/4 rear end, sure grip third member (Auburn Gear), Edelbrock IAS shocks, Firm Feel's rear sway bar, and Wilwood's 12.19" disc brakes with integral parking brake.
At the pace I'm putting everything together, it will be at least a year before I get to find out how the car feels and handles.!
--Walt Jackson
PostPosted: Fri May 06, 2005 12:05 pm
just give it to me and i'll put it all together! WOW that sounds like its going to be nice ride.
Lou--can you detail a little for me on the fabrication end of the swaybar setup for addco?
My dilemma is this (and you guys can chime in).
I can get a stock 65 swaybar with LCA for pretty cheap (about $50) so there's no fabrication there or problems with mounts. Probably need new bushings so add a little for that. I believe that bar is pretty light-duty like 13/16" with #85 wheel rate vs the 1 1/8" with 100# wheel rate of an addco. I just hate the freakin mounts! The FF bars put the mounts higher up and bend them to fit the K member.
I'd prefer to go with ADDCO and do the fabrication work myself if I can. I just need to know what exactly you consider to be a "small amount of fabrication" ;-)
MJ
PostPosted: Fri May 13, 2005 12:10 pm
actually did the shocks (KYB) and sway bars (Addco) before replacing the tires (had 30 year old bias ply 6.50 13's (rears were snow tires)), and had fun sliding around until I could find some rims for the small bolt pattern wheel.
Shopped around on the internet for all of the above and got some good prices.
The Addco bars are bolt on (except for some drilling for bolt holes up front) and are the poly version. The rear is a simple bolt on (poly also). Everything is out of the way, and doesn't hang down waiting to hit the ground (you have some leeway up front of where you put the mounts on the K-member, I tried to tuck it up as high as possible), the ends mount to the lower shock mount and haven't noticed any squeaks.
Finally managed to get some 14 x5.5 rims, and am currently using 195 70 14 tires. The handling is unbelievable...... Flat and neutral. Now I just need a faster steering ratio.
PostPosted: Fri May 20, 2005 5:45 pm
Is it okay for me to upgrade my shocks on the front and keep my NAPA shocks on the back. I'm trying to put off adding a swaybar.
82 D150-225/727
PostPosted: Fri May 20, 2005 6:24 pm
what would leaving the napas on the rear achieve? Having stiffer rear shocks should help the rear springs resist roll and do a better job (assuming the springs aren't shot--in that case you're just going to ruin the shocks quickly) . My springs are pretty close to flat in the back, so I'm in the market for some new ones pretty soon I'm afraid.
MJ
PostPosted: Fri May 20, 2005 9:30 pm
MJ
Just lower the front with the torsion bars............
Much cheaper. :mrgreen:
PostPosted: Sat May 21, 2005 7:36 pm
Get yourself a set of them overload shocks from JC Whitney. these will raise back up the rear of your car, take some of the load off of the springs, and stiffen up the rear suspension significantly. I have a 1500 lb. set on the back of my truck.
82 D150-225/727
PostPosted: Sun May 22, 2005 11:53 am
i'll check into them. I don't really want to raise the rear so much as stiffen it and make sure they are arched. I had toyed with the idea of making some lowering blocks from some box stock steel but its all in the "hmmm" stages
MJ
