It is currently Mon Jun 15, 2026 6:37 am
PostPosted: Sat May 21, 2005 8:27 pm
If I install the new pertronix unit i can get it to run but the mark is not even on the timing tab. Tried installing it 5 ATDC, 5 BTDC to no avail. Not much adjustability on these distributors compared to my chevelle. I assume the firing order is clockwise. Correct. And what should my idle speed be set at on a 72 variety 225 engine. I have way more time invested trying to get this car running than I would care to admit. I have the firing order as 153624 going clockwise. Is this correct. May checke TDC tomorrow wit a piston stop before I go crazy. Thanks.
PostPosted: Sat May 21, 2005 9:19 pm
Car Model: 1964 Valiant 2dr post
Sounds like the gears in a tooth off...is the rotor pointing at number one when the piston is at TDC and the timing set at TDC?
Gearhead
64 GTO...10.80's@122 on street radials
Destroked 455, Qjet, stock ign, 2400 stall
64 Valiant
Old 225, 4spd, 2.92-8.75, 2bbl, headers
dual 2.25"
PostPosted: Sun May 22, 2005 7:01 am
I've move the distributor forward a tooth and back a tooth without sucess. THis is a used motor that we never heard running. Wondering if timing chain may have jumped a tooth or is stretched. Will verify TDC this morning
PostPosted: Sun May 22, 2005 5:51 pm
Did you know that there are two adjustments on these distributors? One is accessed from the bottom side of the distributor. Your correct, the firing order is 153624 clockwise.
Bob D
 Post subject: Thanks to all
PostPosted: Mon May 23, 2005 7:41 am
Bob, Searching the forums after posting I found a response refering to the "second" adjustment nut. Cured the problem and it is now purring like a kitten. Thanks again to all who have responded to my MOPAR questions over the past few weeks. :D
PostPosted: Tue May 24, 2005 1:48 pm
those that want more adjustment on your timing can take the adjuster off a later model distributor. it will give about 110 deg of adjustment.
73 swinger holley 5200, 2 1/4" exhaust .030 over new pistons , cam, .010 under crank. stock everything else. 1/4 mile about a week. 0-60 around 15 sec.
