It is currently Wed Oct 14, 2026 3:33 am
PostPosted: Mon May 23, 2005 8:20 am
My father-in-law has this old tach/dwell meter, but he forgot how to use it. I want to use it's tach function, while I do some timing and tuning. It has instructions on the back label that says to clip the red positive lead to the "primary terminal of the distributor" and the black to ground. What should I clip the red line to? Does it work by induction through the coil wire, like a timing gun does through a plug wire? If it makes any difference, the Dart has electronic ignition.
Jerry
PostPosted: Mon May 23, 2005 8:41 am
Car Model: 1962 Lancer 770
+ on the coil IIRC.
MJ
PostPosted: Mon May 23, 2005 10:09 am
Hook the red to the "+" terminal of the coil. It isn't inductive, so it has to make solid electrical contact.
PostPosted: Mon May 23, 2005 11:10 am
Great, that's what I suspected, but just wanted to make sure.
Thanks,
Jerry
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 9 guests
