It is currently Wed Jun 24, 2026 6:46 pm
PostPosted: Sun May 15, 2005 3:19 pm
http://cgi.ebay.de/ws/eBayISAPI.dll?Vie ... Track=true
That´s around the corner for me. I never thought about wagons but hey it has a six :-) which makes it pretty attractive. huge liquid gas tank, cuts fuel costs in half, a big factor for me (currently about 5$ per gallon, rising)
Chris
PostPosted: Sun May 15, 2005 3:45 pm
That is a cool car
PostPosted: Sun May 15, 2005 11:38 pm
Neat car. I wonder if it was once a US military motor pool car? If it says in the text, I wouldn't know! :wink:
PostPosted: Mon May 16, 2005 11:14 am
I inspected the car today. nice engine bay but LOTS of rust. The whole rear half of the car is full of holes. Old undercoat may hide even more rust. Too much work for me...
PostPosted: Mon May 16, 2005 11:33 am
Car Model: 1962 Lancer 770
How is that possible? My trusty SYSTRAN german translator said this sucker is mint!
"You offer on a rare Mopar b-Body, 66 Dodge Coronet 440 6 of passport-close station Wagon from which I now unfortunately for financial reasons separate muss.440 are called luxurioesere Ausstattung.Der car are so far completely (up to Radio)und over for each 300km at the piece without problems is back more gelegt.Er has a very economical and reliable 225cui Slant Six engine with 3speed manual transmission, sees Fotos.Desweiteren is a good gasanlage blocked with role tank in Kofferraum.Die plant functions and the tank is nearly full in the absolute original condition and is absolute drivingready-has with it already several distances, thus the car is still more economically than he eh already more ist.Er is graceful designed and has the same front, etc. like the bad muscle cars, it gave ` to the 66 also with 426Hemi.Habe the front, bumper already
times polish-polishing that cars is suitable if one it wants also optimally to the Big block change, since he has already the strong 8 3/4 "rear axle (also short translation believes), strong chassis with sway without stabilizer, strong brakes, manual of brakes and manual one could steering.Desweiteren simply a V8 small to block to insert and the transmission use, or with BB switch one can leave however in such a way the Pedalerie the cars, he be because of small Gewichtes.Der engine will run well, will jump became directly more an.Er Teilueberholt.Der cylinder head so already quite briskly became cleaned, other push rods, one Seal blocked, new gasoline pump, new candles, new ignition cables, ergaser(nur little gelaufen), oils gewechs., new distributor cap with finger, etc.-coolly got before some time a new net, to battery again, gasoline filters again, various hose/cables again, tires newly, has still correctly much Profil.Es ives still new brake linings for the drum brake thereby, it is ut.Desweiteren everything in the engine compartment was however still cleaned, new painted, etc.-sees photos, it sees really beautifully aus.Es is still the original cerium TIC pool of broadcasting corporations in Motorraum.Der engine is simply and understandably more aufgebaut.Er has small gasoline a tank in the trunk, because of the gasanlage, I has however the original tank to be procured, to that only cultivated Emergency brake to be times placed behind which I to perhaps still make ability that cars has Netherlands papers and can on 07 old timer characteristics, or also times on h-permission announced more werden.Er brakes, steers, drives like said einwandfrei.Es must for a h-permission in various places (wheel arch, rear flap, to be etc.)geschweisst, original repair sheet metals one can buy (to fit also of Coronet Coupe), but one none is necessarily actually only simple Bleche.Er has these rust places only by the long, because it is not rust at the Rahmen/floor of pans (under the Teppich)des Unterbodens, etc. those weldings are not anything wild for a specialist and can fast be settled, one can however drive naturally first times in such a way (knows the sheet metals and besorgen).Es is a trailer coupling block-blocking those nnenausstatung (seats, instrument panel, etc.)sehen well out, if one deseams all something sees it certainly madly out that skies sees also well aus.Man can the rear seat down turn, then one has still more place electrical connection, heating, light, windshield wiper, horn, etc.-functions
all-original high-grade steel Radkappen.Ich has still another very well received tail lamp to lie, which is I also give-giving that cars as said rather rarely, I has still no second in Germany seen, thus is noticeable one at each meeting, is something special-wanted him correctly beautifully finished for me to actually make, but is because of money after the engine/engine compartment unfortunately stands tremble dear now noetige:Der cars unfortunately becomes without Garantie-und or before looked at and sample driven will only collection should not after auction, Nachverhandlungen.Er must within 5Tagen completely paid could it from me after payment and some weeks (stands in
WARNING: SYSTRAN did not translate the document entirely. The document exceeds the maximum size allowed by the solution.(4096 bytes for plain text)"
I says nothing about being full of rust! How can this be?!!? Must be the translation... :lol:
sorry it didn't work out for you
PostPosted: Mon May 16, 2005 4:22 pm
Basically he's saying the floors are solid, but it has rust in the rockers. I think he said there's some rust around the wheel lip moldings too.
PostPosted: Mon May 23, 2005 5:43 pm
Nice hearse
PostPosted: Mon May 23, 2005 5:54 pm
Cool car even with the rust. /6 three on the tree? couldn't have been to many of those built.
'62 Plymouth Savoy Wagon
'64 Chrysler 300
'47 Farmall H
Merlins are cool
Radials rule
Jets drool
Users browsing this forum: Amazon [Bot] and 1 guest
