It is currently Mon Jun 22, 2026 6:43 am
 Post subject: Bench Testing Fuel Gauge
PostPosted: Sun May 29, 2005 5:48 pm
Is there any way to bench test a fuel gauge? I really would hate to replace a faulty gauge with another faulty gage.
Thanks-DART 68
PostPosted: Sun May 29, 2005 6:50 pm
Thanks-DART 68
Do any testing very carefully, do not, I repeat do NOT ever apply 12 volts or even 6 volts across the gauge terminals, you will fry it.
I have the luxury of test equipment and a power supply with adjustable voltage and current limiting and an understanding of electronics so I am able to do tests that the average person probably can not.
You can test the gauge for continuity with an ohm meter, this will not hurt the gauge. I do not know what resistance value you should read and I do not have any gauges handy to test at this time.
As for a functional test, you can try a 1.5 volt flashlight battery as your power source. Apply the voltage accross the gauge terminals and after a delay the needle should move up. The polarity on these mopar gauges does not matter since they are a thermal gauge, not magnetically operated. It's been several years since I used the above described test using a battery ( I was trying to figure out a way to test the gauges at a salvage yard).
This should get you started. Let us know the results.
PostPosted: Sun May 29, 2005 10:19 pm
Thanks for the info. Would you recommend one battery or two. It seems that two would put out three volts or does it just provide a longer lasting 1.5 volts? I forget the formulas for connecting batteries in series and parallel.
Thanks-Dart68
PostPosted: Mon May 30, 2005 12:16 am
One or two batteries should be fine. One battery should make the gauge show about 1/3 full. If you put two of them in series you'll get three volts which should make the gauge show about 3/5 (a little more then half) full.
Steve G.
PostPosted: Mon May 30, 2005 1:38 am
Thanks for the impute. I'll give it a try tomorrow.
Thanks-Dart68
