It is currently Thu Jun 18, 2026 5:31 am
 Post subject: trunk lock
PostPosted: Tue May 24, 2005 1:42 am
i was transporting a large box in the trunk and it would not shut so i wired it down. when i got home and put everything away i went and shut the trunk and thought nothing about it. the next day i went to open the trunk and the key just turns (no "click"). so, my question is: now i have to go thru the back seat, does the lock have a latch that i can use a screw driver on to release the trunk, or do i have to disassemble the whole thing? thanks.
PostPosted: Tue May 24, 2005 5:51 am
Use a large-blade flat screw driver and it will pop right open.
Happen to have a fold-down rear seat? Otherwise, the cross-brace rear seat support is a bear to shinny between (find a small child). :lol:
Jerry
PostPosted: Tue May 24, 2005 6:48 am
This is where one gets creative with extensions, etc.
While you have the seat back out, check for your build sheet in the springs.
PostPosted: Tue May 24, 2005 8:47 am
good! i had to do the same with my "57" olds. thanks for your help!
 Post subject: fixed
PostPosted: Mon May 30, 2005 5:17 pm
the trunk lock broke. it took me about 1 1/2 hour to fix it so it would work. the dealership here can't help me with parts, do you guys know where i can get a new one? or should i just go to a locksmith? thanks!
PostPosted: Mon May 30, 2005 8:56 pm
ebay, the paddock, year one, bleh bleh blah
my trunk wouldn't open either,
my brother sat on the trunk one day and i went to open it, popped right open
everytime i open it now i have to push down with one hand
70 Plymouth Valiant 4dr
PostPosted: Mon May 30, 2005 10:23 pm
Go to your nearest boneyard. They are very common among many years and many Chrysler products. Take your old one along to check the width between mounting bolts. Might even find one of those remote electric type with the button in the dash. That's what I am looking for. :)
Jerry
PostPosted: Tue May 31, 2005 8:29 am
Those setups SUCKS!!!
When you have the battery in the trunk :oops:
PostPosted: Tue May 31, 2005 8:44 am
Why is that? Unless you mean you have a battery disconnect, and there is no power to open the trunk. :shock:
Jerry
