It is currently Fri Jun 19, 2026 11:17 am
PostPosted: Mon May 30, 2005 5:43 pm
I have finally found a fender for my 73 duster but not sure if it would fit. it's is 76. i believe it might but was wondering if any one know for sure.
PostPosted: Mon May 30, 2005 5:57 pm
Yep, they will interchange.
PostPosted: Mon May 30, 2005 8:53 pm
check the light on the side if it matches up
i got a 73 duster fender for my 70 and the light didn't match up
70 Plymouth Valiant 4dr
PostPosted: Mon May 30, 2005 10:25 pm
'73 - '76 should all match up.
Jerry
PostPosted: Tue May 31, 2005 7:52 am
'69-'71 cars use rectangular flush-mount sidemarker reflector/lights. '72-up cars use surface-mount rectangular sidemarker lights. 67 cars have no sidemarkers, and '68s have round ones. Aside from those differences, '67-'76 Valiant/Duster fenders should all interchange. '72-'76 Valiant and Duster fenders are all identical.
PostPosted: Thu Jun 02, 2005 3:51 am
well i got my fender at the junkyard. thought i got lucky and found a father duster but has i got a closer look no luck was found. . i now know it's going to fit but have one more question.
i've seen coils mounted on the fenders. is this a good idea? does it help keep the coil from getting hot
