It is currently Tue May 05, 2026 8:43 am
 Post subject: 73 Upper control arms
PostPosted: Thu Jun 02, 2005 2:44 am
i was wondering when i change out my drums for disk do i need to get new upper control arms?
one more thing What do i need to Change out my drums to disk. so i can keep my eyes open at the junkyards.
PostPosted: Thu Jun 02, 2005 5:35 am
Yes.
Check this link for the rest.
http://www.bigblockdart.com/dbconversio ... rsion.html
PostPosted: Thu Jun 02, 2005 6:41 am
How many different approaches do you want? Some of the sources even agree on a point or two!
http://www.moparaction.com/Tech/archive/disc-main.html
http://www.earlyvaliant.org/tech/dualmaster.htm
http://www.earlyvaliant.org/tech/books.htm#2
http://duster.moparpages.com/disk_swap.htm
http://www.scarebird.com/6928.html
PostPosted: Thu Jun 02, 2005 6:42 am
Master cylinder and proportioning valve for sure, and possibly the hard lines (unless yours can be bent without damage).
Jerry
PostPosted: Fri Jun 03, 2005 10:04 pm
On a 1973 car you do not have to change the upper control arms when swapping from drum to disc. They do have different part numbers for some unknown reason though so there must be a difference between drum and disc UCA's. But the difference doesn't seem to matter.
PostPosted: Sat Jun 04, 2005 3:32 am
I had a 73 Scamp (definitely all original)and the UCA's had the small ball joint as well as drums all the way around. I seem to recall reading that a lot of 73-76s with drums had that set-up.
