It is currently Fri Jan 02, 2026 4:32 pm
 Post subject: Is 1* a huge deal?
PostPosted: Wed Jun 08, 2005 6:35 pm
I installed my MP268 cam. I degreed it and it came out @ 105*. The factory settings (that I got off this website) say 104*.
Is this robbing me of power?
I read somewhere that advancing the cam gives you more low end, while retarding (which is where I am, right?) gives more peak power. I figure I will get some "help" on the low end with timing advance and I have a 4 speed.
I guess that the factory has 104* for a reason, but this cam seems to be a "project" to some of you who have used it, for one reason or another.
BTW, I have the lash @ .16 intake and .18 exhaust.
Thanks for the help! :)
PostPosted: Fri Jun 10, 2005 5:57 pm
I guess it's not a huge deal.
PostPosted: Fri Jun 10, 2005 8:46 pm
Unless you spend a lot of time on a dyno or dragstrip you will never notice 1*. :shock:
PostPosted: Sun Jun 12, 2005 8:08 am
Me, I would add advance....
and loosen-up the valve lash to .020I and .025E before starting it.
PostPosted: Sun Jun 12, 2005 11:20 am
OK Doc.
Do you mean 20 and 25 lash for cold? Then adjust from there?
I have been running the engine for two weeks now. I just read your other post on lash settings. I will use that method and see what I come up with.
