It is currently Fri Jan 02, 2026 10:13 am
PostPosted: Sun Jun 12, 2005 9:26 pm
Does anyone here have access to an Arvin/Maremont catalog, and could get me the part numbers for the front and tail pipe for a Feather Duster? The one site I've found has comments that don't make it really clear - I think I have it figured out, but want to double check.
Steve G.
 Post subject: Feather Duster tail pipe
PostPosted: Mon Jun 13, 2005 2:28 pm
I printed some of this stuff off the walker web site at the begining of
2004. The 75-76 Feather Duster tail pipe was listed as 45529
muffler is 22067 - converter says see the converter catalog and the
front pipe is listed NA.
I tried to get NAPA to order me the tailpipe about 6 months ago - They
could not find it in their computer - Not by part and not by app -
May have to have a shop with the specs bend a set.
If you find a place to order it - order yours then let me know
so I can order a couple also.
PostPosted: Mon Jun 13, 2005 5:49 pm
The following desciptions are from JC Whitney's website (or carparts.com - same people).
Application: 1976 Plymouth Duster w/225.
Front Pipe:
Arvin 379800 Front Pipe Note: w/o Convert
Arvin 349392 Front Pipe Note: Exc Feather Duster; w/Convert
Maremont EM5273 Front Pipe Note: Exc. Feather Duster; w/Convert
Maremont EX3059 Front Pipe Note: w/o Convert
Tail Pipe:
Arvin 330215 Tail Pipe Note: w/Resonator; (Incl w/o Convert); (Incl Exc Feather Duster, w/Convert)
Arvin 354148 Tail Pipe Note: (Incl w/o Convert, w/Resonator, Used As Res. Sub. Pipe On Mdl. w/Res); (Incl w/o Convert, w/o Resonator); (Incl Exc Feather Duster, w/Convert, w/o Resonator); (Incl Feather Duster, w/o Resonator, w/Convert); (Incl Exc Feather Duster
Maremont T2-2946 Tail Pipre Note: w/Resonator; (Incl. w/o Convert.); (Incl. Exc. Feather Duster, w/Convert.)
Maremont T4-2870 Tail Pipe Note: (Incl. w/o Convert., w/Resonator, Used As Res. Sub. Pipe On Mdl. w/Res); (Incl. w/o Convert., w/o Resonator); (Incl. Exc. Feather Duster, w/Convert., w/o Resonator); (Incl. Feather Duster, w/o Resonator, w/Convert.); (Incl. Exc. Feather Duster, w/Convert., w/Resonator, Used As Res. Sub. Pipe On Mdl. w/Res)
My guess (since it isn't excluded) for the front pipe is either Arvin 379800 or Maremont EX3059.
For the tail pipe my guess is Arvin 330215 or Maremont T2-2946. As I said the descriptions aren't really clear - descriptions say including excluding?
Of course these are quite possibly the wrong ones anyway. I tried checking these using the "ecatalog" on the ArvinMaritor website, but it seemed to be useless.
I was trying to find out for future reference if they were the right parts or not. When I got the car a few months ago I had to get a muffler and tail pipe (for a 76 Valiant), the parts place had a hard time locating them, and then things needed to be adjusted a bit to get it to fit - the tailpipe and muffler were the same diameter pipe and I had to get coupling to put them together. I also had to tie the parking brake cable out of the way because it would rub on the muffler. Removing the cat converter also required some work, since no parts place I checked at the time had a listing for the front pipe. It ended up being a combination of straight pipe, flexible exhaust pipe, pipe size adapters, and clamps.
Users browsing this forum: Google [Bot] and 7 guests
