It is currently Wed Jun 24, 2026 8:46 pm
 Post subject: 79 225 rear main seal
PostPosted: Wed Jun 15, 2005 6:01 pm
Help!! I have a problem with the rear main seal in my demon. The seal in the engine kit fits very easily into the block , it can pushed around with my thumb. The rear main leaks very badly. The kit is for 1962-80 225. Today I ordered a seal for a 1981 slant 6 it is a different part number than the other. The stamped numbers on the block are 9 225 r6 12 2e and the castings on the block are f 530-12 15 12. I took the engine out of a 79 Aspen iI thought it was original but perhaps not. Any advice would be appreciated I miss cruising my Demon
PostPosted: Wed Jun 15, 2005 9:14 pm
You are on the right track, try another seal, a Fel-Pro or other brand name.
If that seal is also loose, go find an old stock rope type seal and use that. Be sure to "pack" the rope seal into the groove and trim away any excess at the parting line.
PostPosted: Sat Jun 18, 2005 7:04 am
Thanks, Ishould have it back in and running by the weeked. hopefully it won't leak
PostPosted: Sat Jun 18, 2005 11:03 pm
bougt a 67 dart today , was always a chevy guy. My family said that I turned ti the dark side, but I am not a cookie cutter guy. I like my dodge,s
PostPosted: Sun Jun 19, 2005 5:33 am
The force is strong with this one... :wink:
 Post subject: no more leaks
PostPosted: Thu Jun 23, 2005 4:12 pm
Thanks guys seal from a 81 225 did the trick. Hopefully back on the road soon for goodguys in columbus ohio.
