It is currently Mon May 11, 2026 4:08 am
 Post subject: Bleeding brakes
PostPosted: Thu Jun 16, 2005 4:29 pm
This weekend I plan on replacing the master cylinder on my 68 Dart
(4 wheel drum, no power assist.). Presently the brakes work but the
pedal comes up when you pump the brakes once while stopping and once
in a great while it will bottom out but comes back on the second pump.
I'm not losing any fluid so I figure one of the two seals in the master
cylinder is blowing by.
My question is which wheel do I bleed first, the one closest to the master
cylinder or the one most distant?
PostPosted: Thu Jun 16, 2005 5:25 pm
Either. I usually start with the farthest away and get closer from there.
PostPosted: Thu Jun 16, 2005 8:25 pm
My manual says to go in this order:
Right rear
Left rear
Right front
Left front
Don't just rely on doing it once, go back and check.
Jerry
PostPosted: Fri Jun 17, 2005 4:35 pm
Thanks guys
 Post subject: No Need to bleed?
PostPosted: Sun Jun 19, 2005 7:07 pm
I replaced the master cylinder and bench bled it on the car (I jacked up
the front to get the cylinder level). I then hooked up the lines expecting
bad brakes and pulling.
To my surprise the brakes work fine, no pulling, no pumping!
Anyone else been this lucky?
PostPosted: Sun Jun 19, 2005 7:08 pm
Bleed them anyhow.
PostPosted: Mon Jun 20, 2005 5:12 am
I agree. You have trapped air in the lines.
Jerry
PostPosted: Fri Jun 24, 2005 6:08 pm
Right, better safe than crashed. It will be a good opportunity to replace
the bleeders with those one-way bleeder valves :D
