It is currently Fri Jun 05, 2026 2:28 am
 Post subject: Carburettor Problem?
PostPosted: Tue Jun 21, 2005 8:43 pm
When I start the engine I have fuel leaking from where the fuel line enters the 'carby (around the needle and seat area). I have tightened the fuel line connection, checked the needle and seat condition, however it still leaks fuel everywhere.
Any help to fix this problem is welcomed.
Thanks, Peter.
PostPosted: Tue Jun 21, 2005 8:47 pm
Inspect the end of your fuel line carefully; the flare may have cracked. Also check for stripped threads where the brass inlet fitting screws into the carb, and check that the proper gasket is used.
