It is currently Thu May 28, 2026 11:26 am
 Post subject: slant six upgrades
PostPosted: Mon Jun 27, 2005 1:14 pm
I've been doing alot of work to my Valiant, but I've left the engine alone since it runs fine. Is it possible to get about 20-25 more hp out of the slant without working on the head, block, or using nitrous? A super six setup is good for 5-10 hp from what everybpody says. What about a super six intake and a header? Is using an Offenhauser 4bbl. intake practical if you're not going to work on the head or make any cam upgrades? Aside from keeping the engine tuned/using synthetics, what else can I do to squeeze some more power out of it? It's a stock 76 engine, with a catalytic converter.
PostPosted: Mon Jun 27, 2005 5:30 pm
If your state doesn't require any kind of emissions inspection eliminating the cat converter would help. An upgrade to a larger diameter exhaust pipe. Replace the stock fan with a clutch fan.
Steve G.
PostPosted: Mon Jun 27, 2005 8:43 pm
Headers or Dutra Duals into single 2.5" exhaust, Holley 390 4bbl or 350 2bbl on Offy intake, recurve distributor. That stuff should get you at least 20 HP. Take some time tuning the timing advance and carb jetting...
PostPosted: Tue Jun 28, 2005 6:08 am
Also do a real careful valve lash adjustment.
As Lou stated, recurve the distributor and make sure the engine see lots of advance right off idle.
 Post subject: how to questions
PostPosted: Mon Jul 11, 2005 8:34 pm
how do you adjust the valve lash?
how do you recurve your distributor?
im also a newbie trying to squeeze out some more horsepower with limited time/experience...
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
