It is currently Sun May 03, 2026 1:08 am
 Post subject: Removing old ball joints
PostPosted: Wed Jul 06, 2005 7:00 pm
I am trying to get my old drums off so I can put on disc brakes.
I am having trouble seperating the lower ball joint from the LCA.
I have a ball joint "lifter". The "pickle fork" did not work on the other side, so I got this other tool.
I have applied considerable force, but it will not come loose (it's probably the 40 year old original).
I was thinking of appling a little heat with a propane torch. Is this not wise?
I do not want to take any chances.
Any other tricks? I tried hitting the part of the LCA around the ball joint.
Thanks
 Post subject: ball joint removal
PostPosted: Wed Jul 06, 2005 8:19 pm
take 2 hammers make sure one is a ball pein style-- place it against the control arm where the stem goes through, now smack the 1st hammer with the other preferably bigger hammer 3 or 4 lb, move this around the joint & it will come off. Another method if your ball joints are no good place this set- up on top of the ball joint stem & hammer away it will mushroom the stem- but the joing is no good anyway!! Enjoy!!!!
PostPosted: Wed Jul 06, 2005 8:25 pm
Heat is fine and might help. Just make sure you heat the part you want to expand, the LCA, not the threaded end of the ball joint. If your "lifter" is that tool that is wedged between the upper and lower ball joints and expands as you turn the threads, it should work. You might put it under a fair amount of tension and give the LCA a sharp whack with a large hammer (worked for me). :shock:
Jerry
PostPosted: Wed Jul 06, 2005 10:08 pm
thanks for dee ad vise
:P
PostPosted: Thu Jul 07, 2005 6:00 am
Even if you want to keep the ball joint, just flip the castle nut over, spin it down until the flat bottom is flush with the end of the stem to protect the threads, then give it a few whacks.
Jerry
PostPosted: Fri Jul 08, 2005 6:28 am
I used the propane torch. It popped after about a minute.
Thanks again
